angel eye led marker
x5inwales
Re: angel eye led marker
Post by x5inwales » Tue Apr 16, 2013 6:12 pm
[quote="MSPORTBMW"]
[quote="Y13HYA"]
you will be fine. Bought many of those before. (for different cars)
Just ensure the black connections are nice and tight on those. You'll know once you see the connectors. Sometimes they can be a little loose. Apart from that all good.
How is the best way to make the connectors tight......I see what you mean....they are very loose.
They are pretty tight when you put them together.
MSPORTBMW
Post by MSPORTBMW » Tue Apr 16, 2013 6:18 pm
My 3w ones were a tight fit.....but the new 10w one I've just fitted are very loose.
Dan1502
Post by Dan1502 » Tue Apr 16, 2013 6:31 pm
[quote="Y13HYA"]
PM me a photo of the ones you need. I might have some spare you can have FOC.
That would be fantastic.  I shall try and sort a picture out later.
2004 E53 3.0D Sport
2016 F25 X5 35D MSport
x5inwales
Post by x5inwales » Tue Apr 16, 2013 7:17 pm
[quote="MSPORTBMW"]
probably haven't positioned correctly. it should be the same as 3w.
MSPORTBMW
Post by MSPORTBMW » Tue Apr 16, 2013 8:43 pm
No the led's are fitted right......I mean the black connector.
Dan1502
Post by Dan1502 » Tue Apr 16, 2013 8:50 pm
Mine were very loose too.  I ended up pinching them with pliers but they still weren't that secure plus the plastic sockets weren't a proper match.  I had to carefully tape them up to secure them.
These are mine without the resistors.
2004 E53 3.0D Sport
MSPORTBMW
Post by MSPORTBMW » Tue Apr 16, 2013 9:09 pm
Hi dan....those are very similar to mine but where yours are a gold colour...mine are silver. Was it the black connectors on the resistors that were very loose?  When I first plugged mine in and trying to make the connectors fit better, my indicator lit up and stayed on.....I thought I'd messed up somewhere......but after a bit of plugging and unplugging, I managed to make the indicator go off....I don't know why that happened.
Dan1502
Post by Dan1502 » Tue Apr 16, 2013 9:31 pm
Yes but in my case the original ones were white and one of the replacements was black but the other end of that one doesn't fit the LED wires.  I don't mind re-wiring them though if I get good resistors.  The components in the replacement circuit looked beefier.
2004 E53 3.0D Sport
Y13HYA
Post by Y13HYA » Wed Apr 17, 2013 8:13 am
[quote="MSPORTBMW"]
The indicator comes on at first until the resistors get to work and 'fool' the car into thinking the LEd's are drawing the correct voltage (when in fact they draw less)
I just used to either chop the connector off and wire directly. Or use a very small screwdriver to make the female pins on the black connector 'tighter'. that way when you push both together they fit snug.
[align=center]2003 Estoril Blue X5 4.6iS - LPG Converted  www.xenon-upgrades.co.uk[/align]
MSPORTBMW
Post by MSPORTBMW » Wed Apr 17, 2013 10:22 am
[quote="Y13HYA"]
[quote="MSPORTBMW"]
Thats great......i will give that a go.  Thanks
