thinking of doing this upgrade to halo xenon lights on my 2002, but so many questions
upgrade of pre facelift headlights
phiggystardust
hi guys
can facelift lights be fitted to prefacelifts, can face lift bi xenons be retro fitted to pre facelift cars (can get hold of a set of these easy) but what else is needed???, upgrade kits you see on the bay, do they come with leveling motors and are they any good??? and on and on,just a few to start off with
2002 3.0d black sport auto, now with added mods!!!re-map,chrome clock rings, folding mirrors,wind deflectors,angel eye led hid's,19"sport wheels,reverse cam,ps2 media+hdd,dvd headrests,alpine v12 amp+sub,+alarm chirp !!!!
- Sanj
Re: upgrade of pre facelift headlights
The facelift lights will not fit into the pre-facelift.
The Xenons are a complicated beast and not to be attempted unless you know your car electrics VERY well. They produce a high voltage to get the gas in the bulb to light up.
BUT the kits are available to get Xenons. They work but remember the legal issues - OEM get self-leveler and washers. Your's will have an adjustable, so not legal. Not one that catches anyone out though - even one's I fitted recently went to the local MOT centre where they adjusted them correctly but never asked about legal issues.
There are many new after-market lights out there that look more like the face-lift one's. Think the pre face-lift was reflective where as the newer one's are a projection type. Hence the goldfish look lens...
AW8
[quote=""phiggystardust""]hi guys
Facelift units cannot be fitted to prefacelift car unless you change the whole front end as they have a different physical shape.
Not sure on the xenon units only so cant comment if they would straight fit into prefacelift units but suspect not.
Afaik the xenon units dont come with self level motors.
I have factory xenon dip beams & will be so bold as to say that whilst good they arent the be all and end all some would let you believe.
The law on these, (if of concern to you), is open to debate but the dft has made its position quite clear in that self levelling & washers would be required. My personal view is that just as illegal plates and tints have had their fair share of attention I suspect bulbs & lighting are up for more legal attention in the future. There is a link to the official dft line on another thread so do a forum search.
Some folk wanting a more modern look have fitted lamps made by depo - if you look in the classified buy/sell section you will see a grey car that had them fitted. I am not 100% sure but seem to recall you may have to import these.
Personally if it were my car I would simply buy the best halogen bulbs I could get hands on, fit those to dip beams get lamps realigned.
If wanting a more modern look the early lights, ( I think there was a switch point sometime in 2002 but uncertain - check xoutpost), on the first prefacelifts can be baked, open & the amber removed. If feeling very creative the amber reflector dremelled out and painted with silver reflective paint, (this would be my preference if freshening up corners).
There are also angel eye kits you can buy............. If upgrading to more powerful, ( technically illegal), halogen bulbs it is important to consider that extra heat might not be too friendly with some angel eye kits. For decent headlamp bulbs google to se what others fitr in your bulb size. Not sure the bulb type but if you check on autobulbs direct it should tell you. Osram Nightbreakers seem to get good reviews as do Philips though technically bright bulbs like the ebay sourceable Diamond vision which have more of a xenon look also are technically illegal in the UK at 5000k. Hoen in USA also export their "xenonmatch" bulbs at a cost but again these are technically illegal in the uk afaik & not E stamped,(again only an issue if this bothers you).
EDITED TO CORRECT MY PRIOR WRONG INFO - ME BAD
Also consider you may wish to change the indicator bulbs to chrome look - due to fitting on original prefacelifts the bladed chrome choice requires overseas consideration of sourcing from USA .
I would say you should ask self what budget you have & what you aim to achive - Is it better visbility or better cosmetics ?
Perhaps be careful what you decide upon not only in reliability terms, but also as molested lamps are a put off for some - come resale.
Whilst confident in assesing the integrity of a used car I am niether a mechanic or a mod guru. Hopefully others will comment with more specific info &/or indeed correct me if I am wrong.
Edit- I posted at about the same time as Sanj, ( who knows far more than me re mods), so apologies for any duplication or conflict in info.
- paulbryson75
sorry to jump on this post - I have had my 2002 lights (halogens) baked, opened up, angel eyes fitted and the orange bits dremmeled out. Really love the way its changed the front of the car - worth every penny! Only problem is I left the orange indicator bulbs in and at certain angles they really ruin the new look - does anyone know where i can get the 'silver' bayonet type indicator bulb??? Am sure someone had sourced from the states on the old forum - any help/ contact details appreciated.
Paul
Paul
02 X5 3.0d SE - Mods: Double exhaust, Angel eyes, orange bits removed! M-Sport steering wheel, e70 X5 Alloys, Aftermarket Sat/Nav DVD with rear screen, Webasto T91 Telestart, skid pan.
AW8
I think as ebay item 270635283631
Or do an ebay international search.
Or try these - memory tells me they are 581 120 degree offset pin spec - check first maybe removing rears which should be the same.
http://www.hids-direct.co.uk/xtec-auto- ... p-405.html
http://www.dcp-shop.co.uk/buy-car-acces ... s_id=20834
BL02WAS
phiggy, get the depo lights!! £180 delivered from germany, wirh fitted halos, self levelling motors, clear lenses, and xenon ready lense for the dipoed beam bulb, with the cut off sheild already fitted so ideal for xenon hid kit!! i have these lights fitted with the hid kit fitted! if you want to see them any time give ne a shout, will meet tou in hwest if helos. let me know. off to Texas on sunday tbough with work so wont be around all next week
- x555
[quote=""BL02WAS""]phiggy, get the depo lights!! £180 delivered from germany, wirh fitted halos, self levelling motors, clear lenses, and xenon ready lense for the dipoed beam bulb, with the cut off sheild already fitted so ideal for xenon hid kit!! i have these lights fitted with the hid kit fitted! if you want to see them any time give ne a shout, will meet tou in hwest if helos. let me know. off to Texas on sunday tbough with work so wont be around all next week
Sent from my iPhone using Tapatalk[/quote]
He can show you his crappy 'gansta' black wheels at the same time
....just don't meet him in a secluded place or the police may turn up and move you on
- paulbryson75
AW8 thanks for that - my mistake though, its not bayonet fitting - not sure what the exact descriptive term is but its a plastic 'push in' type with two wires - like a piece of flat plastic at the back of the bulb which pushes into the fitament. I know I had real difficulty even sourcing the actual orange bulbs when i needed one.think as ebay item 270635283631
http://www.dcp-shop.co.uk/buy-car-acces ... s_id=20834]
- x555
[quote=""paulbryson75""]
I remember that thread your on about as iirc i posted a pic of a facelift bulb and a pre facelift one.......i'll have a look if i have still got the pics for others to see and yes i think they were sourced from the usa
AW8 thanks for that - my mistake though, its not bayonet fitting - not sure what the exact descriptive term is but its a plastic 'push in' type with two wires - like a piece of flat plastic at the back of the bulb which pushes into the fitament. I know I had real difficulty even sourcing the actual orange bulbs when i needed one.[/quote]think as ebay item 270635283631
- paulbryson75
Great stuff - thanks - BMW Part number is 63217164760 i believe, yellow 'wedge type' bulb. I of course after the silver! Cheers
- x555
Found it still in my photobucket pics...
and here's a link to the dimensions etc......haven't seen any chrome ones mind with a quick google search!!!
http://www.donsbulbs.com/cgi-bin/r/b.pl ... a~usa.html
http://www.clipsandfasteners.com/Miniat ... a18476.htm
Have you tried fleabay?
- x555
Right then after a little research via google etc i believe this one will work for you
(do your own further research to make sure mind)
http://www.amazon.com/Sylvania-3357A-34 ... B000AME5GI
Also i am led to believe from other forums etc that the p27/7w or in us terms 3157 will fit the 3757a (your oem one)holder with a little modification to the plastic base
here is further info for the oem bulbs http://en.wikipedia.org/wiki/Automotive_lamp_types
http://www.sylvania.com/ConsumerProduct ... esults.htm
http://www.autobulbsdirect.co.uk/183-12 ... her-Amber/
it may be worth a few emails to the links above to make sure HTH
AW8
Sincere apologies - Yes they are blade fitment.
I like to think I dont have a track record for posting duff gen
AW8
..............it's all coming back to me now.
There was an ebay seller in USA selling sylvania silvastars but on further research I learned tey have a slight blue ball bearing look.
I remember I did more research on xoutpost & stealth bulbs seemed well regarded.
http://www.stealthauto.com/bmw-x5-serie ... bulbs.aspx
Same as comments from x555 - best to check by emailing seller(s) first.
Sorry for earlier confusion - Just to clarify prefacelifts have bladed front indicator bulbs & NOT bayonett.
phiggystardust
cheers mate
yes yours look tidy will have to meet up some time and check em out!!
cheers mate
