Strange engine/gearbox/revving phenomenon
Geezer
Post by Geezer » Thu Mar 28, 2013 7:26 pm
I've got a bit of an odd engine/gearbox/revving issue that I'm struggling to put into words  it here goes....
When I'm driving at a constant speed, usually on the motorway I get this  very slight 'blip' which feels like a very slight hesitation in the engine/gearbox before re-engaging. I've got an auto, I could also describe it as a slight dip of the clutch, or as if the auto box is thinking about changing gear for a split second but hen changes its mind.
It's is most prominent when cruising  or accelerating gently between 40 and 70, below 3000rpm. At lower speeds it either doesn't occur or isn't noticeable., same with higher speeds. Similarly it either doesn't happen or isn't noticeable under hard acceleration.
What is really bizarre is if I engage cruise control it doesn't happen.
I have a 2003 4.6is with 96k on the clock that I have LPG converted. The issue is present when running on both petrol or LPG.
I was wondering whether it was a bad remap from a previous owner or if the air/fuel mix isn't right?
JimmySpeed
Re: Strange engine/gearbox/revving phenomenon
Post by JimmySpeed » Sun Mar 31, 2013 5:13 pm
Did it happen before the conversion? If not, how long after the conversion did it start?
Geezer
Post by Geezer » Mon Apr 01, 2013 12:40 pm
To be honest I noticed it just after i pirchased the car, before the conversion. However, I had the whole car including the gearbox checked out by an Indy called Noel near Solihull before I got the conversion done and he said everything was fine so I just ignored it. Now it's just irritating more than anything when I'm cruising on the motorway.
JimmySpeed
Post by JimmySpeed » Mon Apr 01, 2013 1:00 pm
Noel is a top mechanic. Did he drive it?
Geezer
Post by Geezer » Mon Apr 01, 2013 1:13 pm
Yeah he did, but not sure if he took it for a long cruise, as I left it with him. Maybe i'll take it back to him.
IanP
Post by IanP » Mon Apr 01, 2013 6:57 pm
I think it could be the torque convertor
Geezer
Post by Geezer » Mon Apr 01, 2013 11:36 pm
Thanks Ian, at least that gives me something to search for, I was at a loss to what it could be
