fuel injection indicator on dash display
The foolish fellow
this has been on dash for approx 2 years with no discernable other ill effects. with the 1.4.0 scanner i got the following fault codes
56/3c
any ideas ?
LCM -> Shadow-memory:
56/21 - Fuel injection system
Errors after clear:
Shadow-memory:
56/01 - Fuel injection system
56/3c
any ideas ?
Errors after clear:
Shadow-memory:
The foolish fellow
Re: fuel injection indicator on dash display
2004 3.0d Facelift
The foolish fellow
Bump.........
- Y13HYA
you ever run low on fuel? If you are able to check live data then have a look at your pre-supply pressure on ignition 2 and then on engine idle.
[align=center]2003 Estoril Blue X5 4.6iS - LPG Converted www.xenon-upgrades.co.uk[/align]
The foolish fellow
It was caused by running out , But how do I get rid of the fault. If I clear it it comes back right away
- Y13HYA
have you cleared all air out of the system? Take it for a good blast. or there may be a possibility the pump ran dry and has gone weak, but that is rare.
The foolish fellow
I have this code for over a year now . The car seems fine.
The foolish fellow
Bump again...... Anyone any ideas ?
Smeeagain
just a suggestion. Run the scanner, clear the error, do a hard reset of the system by disconnecting the battery. Worth a shot. I've cleared errors in the past that way but not everytime
