Bluetooth pass code
Buster
Bluetooth pass code
Post by Buster » Mon Nov 01, 2010 4:23 pm
Recently purchased an X5 which has bluetooth but I don't have the pass code for pairing it with my phone. Spoke to the dealer and apparently they don't have it and will need to hook it up to their diagnostic system to obtain it :?
Is there any other way of finding out what the pass code is?
dwgwyther
Re: Bluetooth pass code
Post by dwgwyther » Mon Nov 01, 2010 4:50 pm
Hi you will find it on the Bluetooth central unit in left rear boot area (underneath CD changer). hope that helps. it should be 4 digits.
Darren
Soon very soon to be  X5 40d  :)
Previous - X5 2004 Le Mans Blue 4.8is
Buster
Post by Buster » Mon Nov 01, 2010 7:27 pm
Got it, thanks. All connected up and tested, works perfect.
pvr
Post by pvr » Mon Nov 01, 2010 8:18 pm
And saved you quite a bit ;)
911 50th anniversary -
Smeeagain
Post by Smeeagain » Tue Nov 09, 2010 6:51 pm
Hi - hoping someone can help - i ahve the same issue with not havign the ccode but I cannot find the unti to get the code from. There is a silver box lyign at an angle of 45 degrees below the cd unit - is that it ? If so there is a number but appears to have the code obscured by various mounting brackets which i cant see how to release (will try and psot a pic at the weekend)
smee
x555
Post by x555 » Tue Nov 09, 2010 7:49 pm
That's the one :thumbsup: it's the bluetooth module and iirc my code was hidden behind the bracket :headbang: just undo it and then there should be a four digit code :thumbsup:
x555
Post by x555 » Wed Nov 10, 2010 1:59 pm
Just in case it helps here's what it looks like.... Image
and this is where the code is
edit... re done pics as they were lost with me organizing my photobuket accout :)
gchristofi
Post by gchristofi » Thu Nov 11, 2010 11:38 am
[quote=""smeeagain""]Hi - hoping someone can help - i ahve the same issue with not havign the ccode but I cannot find the unti to get the code from. There is a silver box lyign at an angle of 45 degrees below the cd unit - is that it ? If so there is a number but appears to have the code obscured by various mounting brackets which i cant see how to release (will try and psot a pic at the weekend)
smee[/quote]
Yes, I remember having the same problem when I got my car. You have to remove the unit to see the number. Better than paying a stealer though!
