knocking sound from suspension
Hi all,
My x has developed a knocking sound from what I think is the front left,which I can only hear when I go over bumps in the road ,so Im thinking Sway link . Am I on the right track.
Cheers in advance
dweeb
Cheers in advance
dweeb
Black with Cream Pre-Facelift 3.0d sport.
Re: knocking sound from suspension
Possibly could be ball joint or wishbone or for that matter any one of a number of rubber bits that wear, worn thrust bushes usually cause vibration under braking.
Noises not entrirely limited to suspension.
Excess wear to sway link/ARB's visible to eye. Shouldnt be hard to inspect & easist eway to see if its them is to disconnect then drive over some potholes - if noise gone then they are the culprit. Obviously new ones would be order of the day in that scenario.
Not done this myself & my comments only what I read ages ago within an article to check E46 ARBs - maybe a 2nd opinion may be of benefit before you start messing.
Hi Silly question time but which part are the thrust bushes as I have started to get a bit of vibration under breaking?
Darren
Darren
Soon very soon to be X5 40d
Previous - X5 2004 Le Mans Blue 4.8is
Hi Dweeb
Sound very much like what happened to mine and that was diagnosed as the drop link.
2004 Sapphire Black 3.0d SE
MODS
MODS
[quote=""dwgwyther""]Hi Silly question time but which part are the thrust bushes as I have started to get a bit of vibration under breaking?
Darren[/quote]
Part no.7 is the bush itself
Darren[/quote]
Cheers for that. Top man
OK here we go OEM or Powerflex as a replacement for the thrust Bushes?
Thanks all. Was going to take alook today but lunch at mothers,clocks going back and now the halloween thing with the kids has left me no time,will try and find some time in the week.
Regards
Dweeb
Regards
Dweeb
Darren
I had terrible wobble through the steering wheel under braking. Had Item 10 on the diagram replaced and all is well.
Regards
Dean
Regards
Dean
this all sounds very familiar to my problems right now, drove on the m25 yesterday and the vibrations through the wheel were terrible!!!
I have a slight knocking under braking and the MOT advisory was for bush #7. Can you get the bush by itself, or does the entire arm (#6) need replacing ?
[quote=""Nige""]I have a slight knocking under braking and the MOT advisory was for bush #7. Can you get the bush by itself, or does the entire arm (#6) need replacing ?[/quote]
You can get the bush seperately but you would need a press to get the old one out and the new one in.
[quote=""x555""][quote=""Nige""]You can get the bush seperately but you would need a press to get the old one out and the new one in.[/quote][/quote]
Is this the one that needs that special tool?
If so, is it the same tool Lez bought?
Hydraulic bearing press is no problem
Any suggestions on where I can get one please?
You can get the poly type bushes from polyflex if you don't want change them every 40,000 miles or so, but on the down side you feel more of the potholes in the road through the steering
2003 X5 4.6is - Now dead
