22" Wheel figment for X6M50d ???
westside
Re: 22" Wheel figment for X6M50d ???
Post by westside » Thu Feb 28, 2013 1:08 pm
on my 22 I am running 295/30/22 up front and 335/25/22 rear :-)
Manfromatlantis
Post by Manfromatlantis » Thu Feb 28, 2013 4:51 pm
Thanks for all reply's ...
Well Ive just got home from working away and have a little time to concentrate on the arrival of my X6 M 50d ;-)
The 22's are off my X5 today, and away for a refurb, black satin powdercoat as a base and a gunmetal spray finish for the spokes with a powder clear coating on top to finish. I hope there going to look the business on the X6, after a whole month of looking at rims etc ...
Just wondered how your X6 westside is running on those 295's at the front? is it any heavier on the steering, handling etc ?
Ive got 315/30/22 Toyo St Proxes for the rears and 265/35/22 for the fronts ..... however I do have a pair of 295/30/22 St Proxes which I could use on the front ? Just a little unsure if they will be ok ?
I also have some H&R Trak+ hubcentric wheel spacers for the front which are 30mm and the same spacers for the back which are 20mm. Im thinking that if fitted these should give an even width look to the car ? Im not sure about this but if im correct in thinking the X6 has a slightly narower track at the front to start with anyway ....
Thanks - Rich
Post by X5Sport » Thu Feb 28, 2013 5:02 pm
:X6 has 60mm greater track at the rear than the X5.  How it 'looks' depends on which wheels are used.  Some make it more apparent, but the offsets can of course 'hide it' or accentuate it as you need.
R
Manfromatlantis
Post by Manfromatlantis » Thu Feb 28, 2013 6:16 pm
Yes thanks for the info ....
Im going to be using some 22" onyx , that where on the X5. Thinking they should look well .....
Managed to get some spigot rings for the rears also ....
Just wondered what the difference between the front track and the rear track on the X6 if anyone knows ?
Fingers crosed ;-)
Post by X5Sport » Thu Feb 28, 2013 9:05 pm
In Imperial I know but...
Exterior Measurements
WIDTH: 6 ft. 6.1 in. (78.1 in.) HEIGHT:  5 ft. 6.5 in. (66.5 in.)
LENGTH:  16 ft. 0 in. (192 in.) FRONT TRACK:  5 ft. 4.7 in. (64.7 in.)
REAR TRACK:  5 ft. 7.2 in. (67.2 in.) WHEEL BASE:  9 ft. 7.5 in. (115.5 in.)
Multiply by 25.4 to convert to Metric (in case anyone wondered as not everyone knows that).
R
