[quote="Ash"]
Yes mate that's the sort I'm looking for but just need to find some for a facelift 2005 model!
Well my assumption would be since the facelift already comes with the halo rings and they can be modified by just changing the bulb and the dipped beams are projector type regardless of being hid or not, would have something to do with not having aftermarket options.
With the pre-facelift having two different types of headlight assembly and neither of the two having angels gives a better chance for aftermarket business to make some serious money.
If you haven't done so already, i would suggest upgrading the bulbs on halo rings and upgrade the wattage on the HIDs. If you've done that already than you should just get a oem headlight to replace yours in case something is wrong with your headlight assemblies.
Hello Everyone!
Re: Hello Everyone!
Re: Hello Everyone!
Welcome Ash.
When you say you want to add angel eyes, are you referring to just changing the colour of the existing yellow to white? If so then it's just a simple bulb change.
The side steps pit very easy. One way to clean them up is with wonder wheels and done elbow grease. Does work very well.
LPG has been covered quite a bit so worth just searching for all the threads.
As for other mods, I've done quite a bit to mine so happy to point you in the right direction. Depends what you're after doing.
Re: Hello Everyone!
What extra mods have you done then plus is it any type of wonder wheel I can use because ill grab one from bnq tomorrow and give it ago
