	Changing Angel Eyes - from Yellow to White.
- Gaff
Help needed. I am always one for trying, but has anyone here fitted MTEC LED Ring Marker's before? I have had a look on my Facelift E53, and think I have found the standard Angel Eye ring light, but can't figure out how to remove it. Thinking it would be a twist and turn, then pull out. But that didn't happen! Someone said I would need to remove the entire light? Thanks
			Current:
E83 X3
E90 MSport
'56 LeMans Exclusive Edition X5
Honda Civic 1.6
Previous:
Toyota Previa 2.0 D4D
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
						E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
- ianmaney
Hi Gaff
I didn't remove the light, it is just twist and turn but if I remember right they were a right PITA to get out :/
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
Current Bikes:
GSX-R1000k6 (His)
- Gaff
Re: Changing Angel Eyes - from Yellow to White.
Thanks Ian, I managed to get the old out and the new in, Didn't use the little cable that the new ones came with, and plugged straight into the existing harness, but didn't work   . Was so looking forward. So going to email the guy I bought them from and take it from there. They are the ver 2.1 and not the £80. Ver 3.0 now out. But don't see why they shouldn't work, any ideas? Other than the bulbs aren't working.
 . Was so looking forward. So going to email the guy I bought them from and take it from there. They are the ver 2.1 and not the £80. Ver 3.0 now out. But don't see why they shouldn't work, any ideas? Other than the bulbs aren't working. Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
						E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
- ianmaney
Mine have been in for about 3 yrs now and don't have any cables on them from memory, going to have to take a look now, got me thinking
Sent from my iPad using Tapatalk HD
Current Cars:
Current Bikes:
GSX-R1000k6 (His)
Current Bikes:
GSX-R1000k6 (His)
				Raj
As you found, very easy to remove and fit.
I have tried the mtec ones and a couple of other ones too as the are used on the E60, etc too. Never ever had a problem with them not working and I never used the additional wiring either. Is it only one or both not working?
- Gaff
Both not working. Have posted them back to the ebay seller. Will get a refund and then buy from Ligit shop. Any recommendations? 1st Ebay purchase not to go right.  >:(  but that's life.
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
						E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
- Don Coffey
[quote="Gaff"]
That's the risk we all take when buying from eBay, but as the guy is taking them back with a full refund I don't think you can ask for anymore. In fairness to the seller, he no doubt expected them to work.
Don
Don
				Raj
[quote="Gaff"]
Strange both not working. As above, can't say fairer as refund being received.
hids direct for example do different ones.
- Gaff
Yeah, hopefully he'll get them sometime this morning and do the refund soon after as emailed.
Thanks Raj for the website. I think after these, the next change would be the interior and number plates lights to white. Need to find a good set. Found LED's on EBAY again, a bit doubtful one out of the set doesn't work.
Stay well everyone, have a good week.
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
						E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
				marcm
Just a quick note, if the bulbs are like on the E60 and going into a standard T5 housing you have to make sure you get them in the right way round.  As they are LEDs polarity has to be correct for them to light up.
Im sure you already know but worth a mention just in case.
- Gaff
Cheers, The housing is shaped so that it can only be inserted in one direction. Even I couldn't get this one wrong
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
						E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
- fenj66
i got mine from ebay, cant remember which seller tho. hids uk, hids 4u  etc...
one of mine appeared not to work until i jiggled the wiring of the new led and it eventually came on.
				Kenich
Changed mine back last year from the yellow to white, when one of the side light bulbs went and kept getting the beep everytime I started up and the message, check side/parking lights. As a replacment bulb and holder were nearly £28.00 I decided to upgrade. Ordered the LED's and changed them both out, it was a straight swap. See link below.
http://www.convert2xenon.co.uk/bmw-ange ... rkers.html
Saphire Black E70 X5 40d M Sport.
Mineral White F23 M235i Convertible N55 3.0 Auto
Previous rides, Silver E53 X5 3.0d M sport. & Silver W171 SLK 350.
				graemeX5
[quote="marcm"]
Thanks for the tip couldn't understand why one worked and the other didn't and when swopped left to right the left one then worked on right. Just swopped LED around and Hey Presto both now work
Cheers for the invaluable tip
- Don Coffey
I've upgraded to led angle eye lights.  Nice and simple mod, went with the 20 watt version.  See signature.
Don
			Don
