heater temperature buttons
Jayx5
When adjusting the heating temperature, is there any way of doing it by using 1 button for both sides?
petert
Re: heater temperature buttons
I don't believe so.
Peter T
Peter T
X5LeMans
If you just want a hot boost (or a cold blast), I believe the drivers side control set to +32 degrees or +16 degrees will override the system, and set everything to max (or min), However the on screen display will still indicate different temperatures per side.
My E39 did that anyway, and it has the same controls. Of course with so many BMW functions being coding dependant, you can't ever be sure without actually trying it
