Stereo & OBC
andym3
Stereo & OBC
Post by andym3 » Wed Jan 30, 2013 3:07 pm
I have a 52-plate X5 3.0d, the stereo & OBC broke so am needing to replace them.
If I remove the OBC thats part of the stereo will the indash / speedo area OBC still work using the stalk?
If it does I may buy a after market stereo.
If it doesnt will a stereo & OBC from a E39 fit / work?
CURRENT CARS - E53 X5 3.0d & E30 325I CONVERTIBLE
Gazzi c
Re: Stereo & OBC
Post by Gazzi c » Wed Jan 30, 2013 4:58 pm
Hi I am pretty sure it will still work you will still be able to scroll through the obc but you will not be able to reset the counters on the mpg ect or change the time
E53 3.0i sport, acs foot pedals, acs handbrake lever, acs titanium door handles mirror and fog light inserts, Remus quad exhaust, tinted Windows & E70 3.0 D pretty standard at the mo
Gazzi c
Re: Stereo & OBC
Post by Gazzi c » Wed Jan 30, 2013 5:00 pm
Oh yeah and an e39 one will fit and work just make sure it has th bc button on it as I have noticed some don't have it
andym3
Re: Stereo & OBC
Post by andym3 » Wed Jan 30, 2013 5:04 pm
Ok thanks!  8)
Dont suppose you would know how / if you can fit the BMW X5 TV/GPS Stereo straight in?
Would love to have the top spec tv gps stereo in my motor!  8) :))
Re: Stereo & OBC
Post by Horizon » Wed Jan 30, 2013 6:50 pm
No, sorry you cant retrofit the OEM satnav/stereo/TV into your model. I had the same as you. I have fitted an aftermarket headunit, a Dynavin, or there is the Hooligan ! not spelt like that though, see other posts to check out feedback
http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=8
Steamyrotter
Re: Stereo & OBC
Post by Steamyrotter » Wed Jan 30, 2013 7:54 pm
You can retro fit..
It just needs a lot of time, money modules and another loom.....
The question is do you want to???
There was a company on EBay that supplied the complete retro fit kit for approx £850
Also there appears to be a few American companies that offer the same but a little more plus import etc...
I considered doing that but ended up with Tom Tom on my Ipod touch and a plug in mount.......
And i dont shy away from a challenge that quick...
Please note...
andym3
Re: Stereo & OBC
Post by andym3 » Wed Jan 30, 2013 9:16 pm
[quote="Horizon"]
How did you remove the bracket that makes it a single din to allow for a 2 din stereo?
So with a aftermarket stereo the OBC near the speedo thats controlled by the stalk will still work? I like to keep an eye on mpg etc!  :))
Re: Stereo & OBC
Post by X5Sport » Wed Jan 30, 2013 9:18 pm
You need to install the MID in the glovebox to retain that function.
andym3
Re: Stereo & OBC
Post by andym3 » Wed Jan 30, 2013 9:19 pm
Will need to buy another one then, mine broke!  :'(
X5LeMans
Re: Stereo & OBC
Post by X5LeMans » Sun Feb 03, 2013 3:48 am
If you changing the stereo as well as the MID the E39 Stereo's came with two different connector versions, Round pins V Flat pins.
The MID have various options, so you'll want one that matches your car. The connectors on the mid should be standard on all ages of E39 / E53
Audio
DSP / Telephone
BC / Clock (Seems some just have clock.. Didn't know that!)
A lot of the E39's didn't even have a the MID, just a bigger radio unit.
I might be parting out an E39 soon, My MID has Audio, BC and Clock, but not the DSP/Telephone. All pixels were in good working order. Just depends if I can get rid of the car as a whole as a restoration job.. Otherwise I'll be happy to part it out.
Re: Stereo & OBC
Post by Horizon » Sun Feb 03, 2013 10:27 am
If you remove the Mid, you will have all the functions you have now on your binnacle, I did.
As your Mid is Broken you are unable to reset the clock and consumption settings now anyway.
I put mine in the glove box only to enable me to reset the clock and MPG . When I had it unplugged it still keeps the binnacle display and stork functions.
As for removing the plastic shelf that separates the cd and mid, it's not a removable bracket. It's moulded into the dash, so a hacksaw blade is required, no turning back once started.
I was worried when I started hacking up my dash, but all turned out ok in the end.
The old kit will not fit in afterwards.............
andym3
Re: Stereo & OBC
Post by andym3 » Sun Feb 03, 2013 4:19 pm
[quote="X5LeMans"]I might be parting out an E39 soon, My MID has Audio, BC and Clock, but not the DSP/Telephone. All pixels were in good working order. Just depends if I can get rid of the car as a whole as a restoration job.. Otherwise I'll be happy to part it out.
Ok well if you could keep me in mind that would be great thankyou  8)
andym3
Re: Stereo & OBC
Post by andym3 » Sun Feb 03, 2013 4:20 pm
[quote="Horizon"]
Ok thankyou, got some thinking to do!  :))
kkodal78
Re: Stereo & OBC
Post by kkodal78 » Sun Feb 03, 2013 4:31 pm
Andy
i might have a MID which is out of an E39 if you are looking for one.
