Which battery??
awj85
Which battery??
Taken your advice and looking at the Bosch range batteries. However, on several websites its coming up the S3 is the compatable one for the 2001 4.4 V8?
- Sanj
Re: Which battery??
S5 is compatible - just the stupid website that can't keep up. I have one in mine.
S3, 4 & 5 are all the same dimensions. 90, 95 and 100 aH respectively and 3, 4 or 5 years warranty.
Go ECP and S5. Search on this forum and you should find a compatible discount code (unless they are currently running offers).
storminmike
Re: Which battery??
[quote="Sanj"]
I believe the S5 product code on ECP may be 444770198
- gmc15
Re: Which battery??
Think the ECP code is BATTERY15 for 15% off, but I don't know when it runs out.
x6 M50d
awj85
Re: Which battery??
apparantly the s5 still only has a 4 year guarantee so ought to get the s4 as its slightly cheaper. btw battery 15 is no longer valid ::)
Re: Which battery??
storminmike
Re: Which battery??
[quote="gmc15"]
Normally MGRORG25 gets you 25% off at ECP....so if that's better than current discounts and you can wait then perhaps keep your powder dry for those things "not discounted heaavily in the sale"
Taken from an ECP reply as to why a code doesn't work
Hi Guys,
Just a heads up - our current sale let's you save up to 45% off across our entire product range without the need of a promo code..
The forum discount has therefore been discontinued during this period and will resume once the sale comes to an end i.e. 2nd Jan..
source: Yeh I know....rover ::)
http://forums.mg-rover.org/showthread.php?p=5290253
Hi Guys,
- Ubatoid
Re: Which battery??
This is what I have in mine http://www.eurocarparts.com/ecp/c/Audi_ ... 0&cc5_1001
I did use the code mbclub25 to get 25% off, but its no longer working. A quick Google should find you a code.
2002 4.4 cooking on gas
dark_stranger
Re: Which battery??
I recently brought http://www.eurocarparts.com/ecp/c/BMW_X ... 4a7&000020 as was having lots of battery issues and this fixed it. Dont get a lower spec battery just to save a few pounds as you will only wish you had get a bigger one when you still have power issues.
storminmike
Re: Which battery??
[quote="Ubatoid"]
It's working again
I mentioned above that the 25% discounts were disabled during the sale
S5 works out at £84.55 after 25% off
S3 works out at £68.35 after 25% off
Couldn't find an S4,,,but that's just me
It's working again
- Sanj
Re: Which battery??
Nice one buddy. We have two codes now for the S5 battery on the following link:
MBCLUK25
and
UKPAS25 (thanks to Jeegnesh)
£84.55 from £112.74, not bad!
MBCLUK25
and
storminmike
Re: Which battery??
[quote="Sanj"]
MBCLUK25
and
my long term favourite MGRORG25 works also too
MBCLUK25
and
mikem
Re: Which battery??
The 019 S5 has gone up to £130 at ECP now !
It's only £103 at carparts4less though and they've got £15 off when you spend over £100, so £88 delivered.
lynxjock
Re: Which battery??
New Bosch S5 just arrived in post, is it a simple change over or do I need to do any programming to match the battery to the car ?
2013 BMW X6 40d, white with vermillion leather
Re: Which battery??
Straight swap in the E53. It's only the later models that need to have the battery coded - and the coding is only so that the car can monitor the 'charging state' of the battery.
Remember to attach the vent hose and plug the unused hole (there should be two options on the S5).
