Painting - opinions please
Moving house next week and need to paint 6 rooms by myself but fast. Is the good old paint roller still king or should I go down the route of paint pods with attached hose and brush thingy or even one of the paint sprayers (as the house will be completely empty so no need to worry about stray spray!)????
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'03 Renault Clio 1.2
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
- Don Coffey
Re: Painting - opinions please
Spray. I would consider hiring as these will be better quality. As a rule spraying will put a thinner coat on the walls so my need more coats, but will be much much quicker and drying times will be quicker as well. It will however take longer to mask off, cover windows, doors, skirting board etc. but as you have six rooms it will still be far quicker and no where near as fatiguing.
Don
Just to confirm, you need a High Volume Low Pressure HVLP system.
Don
The good old roller is best no masking to do etc lay your dust sheets cut in and crack on that's what I use on my place 6 floors and 15 rooms in fact starting mine Monday and your quite welcome to pop in and help .
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Current
Jaguar XF
Previous
BMW X5 3.0D
I do the edges with a small (2") brush and the good old roller for the larger areas - with an extension handle for the stairwell. Even used a roller to put stain on the outside wood planks (supposed to make a 1999 house look like a farmhouse according to the builder.. ??? ) and it worked surprisingly well..... . Not allowed up ladders see, well not 'officially' anyway.
do these paint pads actually work or do you need special pink paint (as seen on tv }
Very tempted to go for spray as I'll be doing two ceilings which have very intricate cornicing (from 1874) which'll be a nightmare to paint by brush.
Plus, I'm a gadget geek so any excuse to try a toy out.....
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
Sprayer all the way for me and no brush marks either, this method uses less paint too, got a mate with his own decorating business and most of the time its all he uses!
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
Current Bikes:
GSX-R1000k6 (His)
Decision made - HVLP sprayer hired for a week (I'm working during the daytime too) and picking it up next Sat morning. Cheers for the help folks!
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
So I've hired the sprayer.... Now can't get it to work. No paint coming through at all. Have thinned it and thinned it so definitely not that. This is the gun I have, the gold coloured bit at the bottom goes into the little paint pot that attaches to the gun. I assume there should be some sort of suction from the end of this bit when it's running? Not getting anything at all just now..... Or will there be no suction because the pot isn't attached?
Can anyone help?
Can anyone help?
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
- Don Coffey
Hi Chief,
Put some water in the pot and attach. If no water comes out then it certainly isn't the paint thinkness. The black knob at the top rear is used to regulate the amount of liquid to air mix, so try opening this to see if that helps.
The knurled knob directly above the black grip controls the amount of spray that comes out when pressing the trigger. Don't have this open too much until you get comfortable with it. Better to under spray than over spray.
Hopefully this will help.
Don
Don
This is going to get messy...lol ) I've got visions of that Mr Bean sketch with the firework and tin of paint !
[quote="Barney"]
[/quote]oh ye have little faith!!!!! You are correct though...... D'oh!
Turns out that on the wee plastic tube connecting the pot to the gun there is a non-return valve and someone (not me!) had connected it upside down so no air was getting to the pot. The air goes via this tube into the pot pushing the paint up the gold coloured tube into the gun. Got it working to a fashion but pretty rubbish. Might have to rethink my paint if I want to keep using it....
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
Get the roller out mate the good old fashion way its the best way by the time you've got it going/used to it you could have done it all.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Current
Jaguar XF
Previous
BMW X5 3.0D
[quote="Reusch"]
[/quote]its being seriously considered. I'm ahead of the game plan wise so today was a bonus painting day so still on track. If I can get it working well then it'll save me hassle in the long run but I ain't spending much more time trying!
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
Looks like an HVLP sprayer isn't ideal for emulsion - an airless sprayer looks like the way to go.....
Current:
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
'09 35d MSport X5
'09 E92 M3
Previous:
'07 3.0si Z4 Coupe
'07 Golf GTI
'05 Civic Type R
