I`m new on this foum, and after reading some treads I`m impressed of the level off "know how" and "how to"
Since my Webo faild, I`ve read nearly all post`s and treads regarding this subject. Wich lead me to that I tok the webo out of the car, dismatled it, cleand it and put it back in. The first start was a stroke back, but on the second try it worked, and it have worked since.
My car has the MID display (not NAVI), but in addition to that, on the left side of the steeringwheel (left wheel version) ther is a Standard Webasto-timer display. Both is working, and I can set the time or direct start the heater from both.
Any one else who has this solution?
The next step is a telestarter. Either GSM-based or the Cars System T91
http://www.carsystems.pl/bmw-webasto-te ... id182.html
Is this OE, or just "wanna be"??
When the webo is used as ha parkingheater, the heaterfan starts to blow, but i wold like to increase the speed of the fan. Is it possible to cange this setting?
After 20-25 min runtime on the Webo, the engine temp when start, is a bit above the blue area - is this normal? (I live in Norway and the last week we have had like - 13 C at night.....)
Since my car only have the MID, I`m considering a none orginale navi/radio sollution. Hauligan or similar. What happens with all the functions on the MID if changin to a none OE navi unit....?
Best regards
 XLoke,
 XLoke, really pleased that you were able to get the Webo sorted, you would certainly benefit from it in your part of the world. I was lucky enough to visit in 1987 and what a beautiful place it is.
