White van drivers!
White van drivers!
Hi guys
Today a white van drove into my parked car and ripped off the wing mirror! He got away with it as he was to quick for me to get his reg!
So I am left with a busted side mirror now. Got it all apart and the only broken part is the metal cylinder that goes over the top of the electric motor. I have glued it back together but wont hold my breath!
Ive been on realoem but the part I need is not listed and appears to come under the most expensive bit which includes the mirror etc.
Does anybody know of a quick fix or able to get parts for these mirrors rather than buying a near complete assembly from ebay or worse BMW?
Re: White van drivers!
White van,taxis and buses. >:D
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Current
Jaguar XF
Previous
BMW X5 3.0D
[quote="DevonX5"]
Today a white van drove into my parked car and ripped off the wing mirror! He got away with it as he was to quick for me to get his reg![/quote]
Wanker! >:(
[quote="DevonX5"]So I am left with a busted side mirror now. Got it all apart and the only broken part is the metal cylinder that goes over the top of the electric motor. I have glued it back together but wont hold my breath! [/quote]
How's it broken, can you get a tie-wrap around it, as well at the glue?
[quote="DevonX5"]Ive been on realoem but the part I need is not listed and appears to come under the most expensive bit which includes the mirror etc.
Does anybody know of a quick fix or able to get parts for these mirrors rather than buying a near complete assembly from ebay or worse BMW?[/quote]
Never seen it myself.
Wanker! >:(
Hi guys. Thanks for replies
Its the base of the metal cylinder that has broken into 5 bits (2of which are lost). A good idea, the tie wrap, but wont work in this instance. Im leaving the glue to set overnight but judging the strength of that gold spring on top of the motor I think it will just break
Can you wrap a single layer (or more if room allows) of fibreglass mat and then resin the two 'layers' together?
Just an off the wall thought.
R
R
Barstewards
No breakers round your way? Used internals are easier to hide/stomach.
Sounds like a plan!
Only problem I can see is that the internal part is almost an interference fit but the outside might be ok to do. Failing that I might try and get it welded up or make up a new bracket out of some alloy strip.
Im still not sure if BMW do this part on its own? A quick call tomorrow should sort it.
[quote="snipez999"]
Barstewards
Yep will give that a go. Ebay seems to only have the whole assembly for £250 upwards!
Barstewards
Partsgateway.com
- Don Coffey
What a tosser! :rant:
I have a dash cam (cheap one) but intend to upgrade to one that records when the car is parked as well, just for such an incident.
Don
Don
Trying partgateway now
[quote="Sanj"]
Wanker! >:(
Brilliant I thought this forum had swear monitors
Obviously it fucking doesn't! How shit cool is that
See you next Tuesday!
Wanker! >:(
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
Swear monitor like me you mean?
911 50th anniversary -
[quote="pvr"]
You don't count!
You don't count!
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
You can take the Audi driver out of Essex.........
