[quote="wilkoturbo"]
Right I have wired power to pin 1 via a remote it powers up for like a minuite then shuts off , I've read the fault codes what next <!-- s:( -->:(<!-- s:( -->
Did you happen to enable the Nav screen for Auxiliary Heating / Ventilation? instead of the original Auxiliary Ventilation setting
I beleive if you did - the Nav screen is communicating with the IHKA and other components before starting the webasto. You will probably find the IHKA is not the one suitable for SA536 option, and you will not have the valve that is mentioned in your fault code. As well as this, other parts of the system are missing as you do not have the factory fitted Parking Heater.
This is the point I am at, although I am also showing a glow plug short circuit to ground fault.
I am waiting to recode the Nav screen back to its original setting, then take it from there.
