Hi guys, could do with some advice. Recently I have noticed the radio reception on FM has become poor, I have googled etc but seem to have had very little luck.
If anyone has any ideas what the problem could be (before I spend most of tomorrow scratching my head) please let me know. I am recieving certain FM channels but the reception is barely audible.
Poor radio reception
- Turks
- Contact:
Re: Poor radio reception
I presume that you haven't had your head unit out for any reason recently?
I think the Aerial is in the rear 1/4 glass so it can't be that unless something there has been disturbed / damaged.
Turks.
Turks.
Present:
Past:
Past:
x5south
Hi Turks.. No the head unit hasn't been removed,nothing touched disturbed or visibly damaged.
Glenn822
Hi, did you get it this sorted. I note that that you posted your problem in October when you possibly started to use your heated rear screen. I have a similar problem put only when the screen heater is on, so it's no great shakes as it's only on for a few minutes in the mornings
x5south
Hi Glenn822... Nothing was altered and the reception issue seemed to disappear. all is good again now... Very perculiar although a nice "cheap" fix.
- tractorjacob
[quote=""Glenn822""]Hi, did you get it this sorted. I note that that you posted your problem in October when you possibly started to use your heated rear screen. I have a similar problem put only when the screen heater is on, so it's no great shakes as it's only on for a few minutes in the mornings[/quote]
Mine does this also, soon as I turn on the heated rear window the radio starts going mental.
Anyone know of a way to sort this? I presumed it was down to a bad earth but had a look and couldnt see anything.
