Buying number plates...online
I need to change my number plates (not the number) as they're frankly pants and oddly wearing out.
I notice that you can get SHOW anc REAL plates online yet I thought that regs meant you had to show your documents over the counter as some sort of proof. Is this true?
On a question of style and correctness I noice they have to carry som e BS info but almost all I see carry garage names. I'd rather have none or at least what I want
The wifes X5 has a slightly bigger (height) rear plate and that seems to be more in proportion too
Thoughts...costs?
For me simple is good enough....no flags or stuff and being silver I think a border (colour?) may be right?
Thoughts...costs?
Re: Buying number plates...online
ive used myshowplates.com many times now and had cars mot'd with them on fine, also you can have them with no writing on the bottom
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
I have 2D plates that i ordered online for the X5 and have 3D plates on the VW and no problems. Passes MOT no problems.
Sent from my iPhone 4S using Tapatalk
I paid £13 per pair for mine(s).
[quote="kkodal78"]
[quote="shadrack"]
Thanks for that...I guess that means you don't need to show your V5 then?
[quote="shadrack"]
[quote="kkodal78"]
Cheaper than I thought
no documents required
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
'3D' plates aren't an MOT failure.....permitted under Sec 6.3.
Some suppliers will require documentary proof, but not all. If you are buying from Halfords as I have for trailer plates, then you need to supply documentation as per the link.
[quote="shadrack"]
How bizzare...I thought they were trying to stop clone plates
On show plates site you can delete the BS bit.....I guess that has to stay to be legal?
I found my supplier from fleabay. There are tons of them and i also requested the GB option to be added this way i don't have to put a sticker when i drive over to mainland europe.
GB mark is legal too. Licensed/Approved plate suppliers in the UK require proof of 'entitlement', but with Fleabay then anything goes - legal or otherwise.
Not fussed about GB....what I did notice was the British Standard BS bit could be deleted online, that I thought might cause trouble....but the again you can get stickers
Mine got a WELSH dragon on it....and I'm not welsh )
Don't get me wrong when i say from fleabay i don't mean someone printing the number pkate in their garage. I bought it from a company who sells thru fleabay with all legal requirements met such as writing at the bottom, legal distance between the number and borders and spacing etc. they just gave me an option between 2D abd 3D.
[quote="kkodal78"]
It's all right kkodal, but a couple of years back there was a serious problem with dodgy plates from the likes of Fleabay - mainly from 'offshore' suppliers. The 'anti-clone' drive then running in the UK was being completely circumvented as it was way too easy to get anything you wanted made up unchecked including non-UK plates to disguise a car.
UK Suppliers are supposed to check ID, but then l guess if anything goes wrong then it's their neck on the block, not the buyer's! Cloned plates generally was a serious issue 10 years ago (I had several instances on the UK Gov't Fleet I ran - bad choice for the cloner though!) which was when the rules were tightened up. Until then anyone could knock plates up as you said 'in their own garage'.
I am surprised that the suppliers aren't making more checks though... ??? Kinda defeats the whole idea of tightening the rules.
The official & correct line is plates fitted on uk cars are required to comply with BSau145d & must be supplied by a Registered Number Plate Supplier, (RNPS) ,who should ask for proof of registration & a suitable document to confirm correct name and address.
Specific rules exist re plates for legal uk road use and with reference to fonts, sizes and spacing etc. There aren't any restrictions on max rear plate size so long as you otherwise comply hence the slightly larger than the norm rear plates seen on Rover 75, X-Type Jag, some RRS, X5's and other cars with large rear plate recesses. Conversly a smaller plate than normal can be used so long as it is otherwise BS compliant including character size, font, spacing between characters, groups and complying with min distance from extremes of marking to the physical plate edges, ( though few make legal smaller physical width plates for say 5 character registrations)
Plates should display the correct Bs mark as mentioned as well as plate maker details.
More info by clicking [www.dft.gov.uk/dvla/forms/~/media/pdf/l ... /V796.ashx] here[/url]
Totally accept folk buy various plates from various sources & thus compliance is a personal choice albeit with possible varying, (perhaps insignificant to some), consequences depending on what is fitted.
