BMW X6 21" alloys & tyres
syg9m
Post by syg9m » Wed Oct 03, 2012 10:25 pm
still for sale the tyres must be worth £500 without the wheels 325 / 30 / 21 6mm + , The wheels are in very good condition cost over £4800 upgrade
Raj
Re: BMW X6 21" alloys & tyres
Post by Raj » Wed Oct 03, 2012 11:38 pm
How much are you asking?
Sanj
Post by Sanj » Sat Oct 06, 2012 9:28 am
Are these the 128 style?
Si
Post by Si » Sat Oct 06, 2012 10:03 pm
Will these go straight on an X5 ?
Post by X5Sport » Tue Oct 09, 2012 7:56 pm
Definitely need arch extensions in order to avoid issues with the tyres extending beyond the legal limits.  If in the 12 o'clock position the tyre tread area extends beyond wheel arch it's an MOT 'Advisory' and might even get failed as having bodywork or parts extending in a dangerous way.
Raj
Post by Raj » Wed Oct 10, 2012 7:02 am
Richard, is it not a case that the tyre being round in circumference as is a clock, then it is always in the 12 o'clock position not a matter of 'IF'...... ???
Si
Post by Si » Fri Oct 12, 2012 6:55 pm
I have an E53 sport which has the slightly wider wheel arch extensions, so will these be ok or will they rub ?
Pictures ?
[quote="syg9m"]
hi only an E53 with arch extensions I think ! The fronts will fit an E70 but rears have smaller bore size 72.6 compared with 74.1
Sanj
Post by Sanj » Fri Oct 12, 2012 8:27 pm
They won't rub, just need the spigot rings (I think), Raj knows for sure. I get confused easy, nowadays...  ::)
Post by X5Sport » Fri Oct 12, 2012 9:53 pm
[quote="Raj"]
:doh: It's where the measurement is taken, as in straight up from the top of the tyre to wheel arch.  MOT Testers have to be told where to check it apparently.....Can't get the techs these days...... :))
Raj
Post by Raj » Sat Oct 13, 2012 8:52 am
[quote="Sanj"]
Centre bore in the E70 is 74.1 whereas E53 is 72.6 so you will indeed need spigot rings all round.
Raj
Post by Raj » Sat Oct 13, 2012 8:54 am
[quote="Raj"]
Ahhh sarcasm is lost on the old..... :P :)
Post by X5Sport » Sat Oct 13, 2012 2:37 pm
Aaaaah, right,........well........in that case you can't get the comedians either...... :P  8)
Raj
Post by Raj » Sun Oct 14, 2012 11:16 pm
Touché ... Lol
