My radio is becoming somewhat of a major irritant and having searched around, I can't seem to find anyone who has experienced a similar problem.
Effectively, the radio is fine but every so often the volume almost goes to nothing for a second or so, but then goes back to normal.
Playing CD's is fine but I can't fathom what's wrong with this radio. I've checked connections to the Radio module in the boot and all seem fine.
The car is a 2003 53 4.6iS with Nav, Bluetooth, Radio and CD Multichanger.
Any ideas would be gratefully received.
Andy
Radio problems...........
- M3 SOY
- CondorX5
Re: Radio problems...........
It may have fallen victim to the dreaded dry joint issue which affects these radios - there are threads on here about it, and someone who does repairs to the radio PCB. AW8 had this problem and got it sorted eventually, I think......hopefully someone will be along soon to point you to the thread(s) about the radio problems!
X5 2005 Le Mans Blue 4.8is
- parasuper
If you have the sat nav disc with speed camera pictures on, then it will quieten the radio every time you approach a camera. This happens if you don't have the function enabled. Hope this is of help.
E53 4.8is 55reg Carbon Black
Honda Pan European ST1300 2007
2 King Charles Cavaliers
- M3 SOY
I do have the sat nav disc with speed camera pictures on it. I'm going to have to check now when I drive it. If that does turn out to be the case, is there a solution?
The camera pictures just appeared on my latest disc.
- parasuper
Don't know of a cure. You can switch it over to the voice recognising the speed camera's which is a pain in the area where I live because there are so many of them. Also, if I remember, something comes up in french language when the voice warning is activated.
- M3 SOY
Well, its not the sat nav cameras I tested that. It just does it randomly on all radio stations. Sounds like the module could be the issue then!
