Rear hatch soft close not closing?
Legeek
Post by Legeek » Fri Jul 27, 2012 8:50 am
Hi,
I am having real fun with my E53 finding out all these options that I have but unfortunately do not work. The manual tells me about the Rear hatch or door soft close, in principle I only have to push it down lightly and it will close itself.
My wife and I are able bodied so we do not really need the option but hey... if it is there it should work right?
And if I push down lightly (or not) well not much happens... I checked the fuse which is OK. It is not in the manual referred to as an option so I suppose it is there on all E53's? Mine is the 3/0D sport Sept 2006.
Is is in actual fact an option and I do not have it (in which case not sure why Fuse 82 is in place since this is all it does) or is it something I can find out when I get the scanner (hopefully soon)
By the way I really enjoy my X.  It is just typical BMW with the electric funnies... I had a 530D and it took me 6 months to get all options to work. So I will get there eventually.  :)
JC
BMW 2006 E53 X5 3.0D Sport
Mini Cooper 2007
LincsX5
Re: Rear hatch soft close not closing?
Post by LincsX5 » Fri Jul 27, 2012 9:08 am
Hi, this is a bit of a misnomer really. All it does is pull the hatch in the last cm softly so you don't have to slam it shut. When I first starting looking for an X5 I thought it was like a power closer for the full range of movement too. So as long as yours pulls in that last little bit, you will here the whir and click, then it is working as advertised.
2008 E70 3.0D SE Dynamic kit
2006 SAAB 9-3 Aero
2004 E53 3.0D Sport. Heated steering wheel, Remote Aux heat, Arches, Skid plate. SOLD
2002 E46 318Ti SOLD
1972 Triumph Spitfire
Legeek
Post by Legeek » Fri Jul 27, 2012 11:14 am
Ahh right. Thanks for that. At least it was an easy fix. I suppose it does the trick then as it does close without me having to slam it shut.
JC
Mini Cooper 2007
