Urgent - Need a THIN 18mm spanner, where from?
Raj
Basically started to strip the air suspension out of the X this evening. Control module is out and near side front shock/airbag is out also but the drop link bolt requires a thin spanner to hold the bolt in place so as to be able to undo the nut. Need to pick one up today to carry on.
Anyone?
Thanks.
Anyone?
Thanks.
- macky1986
I would either grind down an old one if you have one or try getting vice grips onto it.
Raj
Re: Urgent - Need a THIN 18mm spanner, where from?
[quote="macky1986"]
Don't have a grinder and vice grips think are still too wide. Hmm.
weirdfish
You must have a small engineering shop/garage around you, they will do it for a few bob.
Raj
[quote="weirdfish"]
Little search has highlighted its actually 11/16" needed for the back of the drop link. Just ordered a new pair of lemforder drop links from ECP with the TEST31 code and will head to Machine Mart to pick up a spanner suitable for the job. Always good to have specific tools...lol
dirtymonkey29
Are you able to wedge a flat blade screw driver between the nut and something to stop it spinning?
Raj
[quote="dirtymonkey29"]
Unfortunately not as it's just way to tight a gap. Tried some pinch grips I had but that ended up popping the rubber boot off... :'( hence now deciding to replace the drop links (but not a bad thing really).
dirtymonkey29
Break out the hammer lol
Raj
That's the first tool that is always brought out at the beginning of any job...lol
- shadrack
while your up at machine mart why not invest in a grinder as well, very useful to have and cheap
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
[quote="shadrack"]
If nothing else, you can have fun finding the bits 'launched' by the grinder to the furthest corners of your workshop......
Remember to change the head next time you're doing a machine polish though..... :'( :'(
Raj
[quote="shadrack"]
Never really needed one before so not sure it's a worthwhile investment at present.
nigelwall
I would buy a cheep 18mm spanner and put it on a grinder and grind it to the width I need.
Cheers Nigel
Cheers Nigel
- shadrack
[quote="Raj"]
[quote="shadrack"]
honestly it is, i bought a grinder brand new once for £5 cant remember where from tho
[quote="shadrack"]
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
Raj
Sorted thanks to Zamir off here. Got an 18mm cone spanner (kind used for bicycles) from the decent chap at Halfords. £5 deposit and away I go.
Coilovers are here but after a slight mix up and misunderstanding I'm missing a small BMW suspension component which I'm going to have to order in the morning.
