Help on rear light failure
X5DOB
Post by X5DOB » Sat Jun 09, 2012 11:14 pm
I know this has been mentioned before, but my rear inner light has filled up with moisture and has now failed! Do I have to replace the whole unit, or can you just replace bulbs then re-seal it??? Car not under warranty anymore!
Cheers.
stevox5
Post by stevox5 » Sun Jun 10, 2012 9:42 am
If its an E70 ie 2007 onwards you will probably find the internals of the unit are  Badly corroded , if it's just damp try drying it and cleaning with electrical contact cleaner first before replacing.
There is a modified rubber seal now available to fit instead of the sealing tape it originally had. I would fit the modified seals to both lamps if I were you.
Hth
X5 3.0i Topaz Blue , Paddle shift steering wheel , Pioneer double din sat nav,Alpine speaker upgrade,  Remap, HID's,20inch lemans alloys,lemans arch kit,Depo light kit,carbon fiber interior wrap.
X5DOB
Re: Help on rear light failure
Post by X5DOB » Wed Jun 13, 2012 12:03 pm
Yeah its a E70. No it is 1/4 inch full of water so yeah I think its a full replace job.
I have found a replacement light but it comes without a new seal, does anyone know where I can buy these??
stevox5
Post by stevox5 » Wed Jun 13, 2012 7:42 pm
Main dealer only mate not expensive though.
X5DOB
Post by X5DOB » Fri Jun 15, 2012 7:55 pm
I know someone who works for a BMW main dealer and spoke to him about this problem and he said that he's never heard of a foam replacement, they just stick them on again using that butyl crap?!?
Has anyone brought these foam seals separately and where from please?
Post by X5Sport » Fri Jun 15, 2012 8:02 pm
Is it item 9 on this diagram on Realoem by any chance?  It doesn't say what it's made of though.
Same part number is used right through to April 2010 when the LCI came out.
There is however this version used on the LCI, which looks like a different material and if the same shape might be what's being referred to?
stevox5
Post by stevox5 » Fri Jun 15, 2012 8:49 pm
The tape he is on about is what is fitted originally and why they leak!
I would either speak directly to the parts department or try a dealer that knows what they are talking about.
I could get you the part numbers Monday when back in work if need be.
X5DOB
Post by X5DOB » Fri Jun 15, 2012 9:27 pm
That would be brilliant stevox5 cheers. Its the passenger inner rear light. 2008 E70.
Thanks.
stevox5
Post by stevox5 » Fri Jun 15, 2012 9:55 pm
Will do no problem
