Hi,
Does anyone know how to reset the panoramic roof ? I had a flat battery and since then the vent part open and the sliding cover are working ok the problem is the front sliding glass section will only open or close inch by inch!
Steve
Panoramic Roof
- cognac
Panoramic Roof
2005 3.0D Sport Highland green beige leather with some nice extras..
Previous toys.
White RS6 avant
CL55 AMG
S4 Avant
Previous toys.
White RS6 avant
CL55 AMG
S4 Avant
Re: Panoramic Roof
Try this.....
PANORAMIC SUNROOF RESET
When resetting the panoramic sunroof, it cycles through two modes. The first is Normalisation, where the end positions are learnt. The second is Initialisation, where the characteristic curve is learnt.
The procedure takes 75 seconds. It begins by having the floating roofliner in the open position and the sunroof completely closed.
The centre of the sunroof switch is then pressed and held in the Lift position. Note: the switch must be kept pushed for the whole procedure. If you release the switch before the procedure is finished, you must start again.
The roof then moves to the lift position, the floating roofliner closes then opens, the sunroof then closes from the lifted position, then opens and closes fully, the floating roofliner then closes and the procedure is finished.
Never anthropomorphise computers. They hate that.- cognac
Re: Panoramic Roof
Thank you very much for your advice X5sport worked a treat.
Steve
Steve
Previous toys.
White RS6 avant
CL55 AMG
S4 Avant
Previous toys.
White RS6 avant
CL55 AMG
S4 Avant
