X5 radio stopped working!
Hi guys, my missus has just told me the radio will not turn on, so I've had a quick look and everything works like the time and BC but the radio doesn't! Any ideas? Thanks
X5 3.0d sport
Re: X5 radio stopped working!
Can't remember which one it is, but there's a reset procedure for this, you have to remove the relay/fuse wait a minute then re-fit, worked for me.
Sure someone will be along in a minute with either a link or better explanation, or try doing a search.
A quick search reveals that if it's just a reset then fuse no 7 in the glovebox and fuses 72-73 in the rear compartment need to be pulled, but double check on the fuse identification panel before removing.
The above fix mine remove all and then refit all, don't just pull one and refit.
Sent from the Iphone via talktapa
I've just tried pulling all these fuses and no joy! I ain't got sat nav on my car so is this still same procedure? Thanks anyway
X5 3.0d sport
Jobs a gud in! Took the radio out to check the little 10a fuse at the bck and it was blown! So I was wondering why then I heard sommat rattling around inside, my 2 year old twins had posted penny's through the cassette slot
so bck happy again
X5 3.0d sport
