Rear suspension [squeak]
X5Driver
Post by X5Driver » Sun Mar 25, 2012 6:36 pm
Sometimes the garage is the best place for certain jobs especially when you can't be frigged
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
macky
Re: Rear suspension [squeak]
Post by macky » Thu May 10, 2012 11:36 pm
Lower hub carrier balljoint is the usual suspect for squeaking defo not a DIY job unless you have the correct tool to press the new balljoint in and out of the hub carrier, the only way to get a diagnosis of worn rear suspension parts is to release the air from the air bags otherwise the suspension is under load and wear cannot be located, thats why so many X5's with knackered rear suspension sail through MOT's.
dirtymonkey29
Post by dirtymonkey29 » Fri May 11, 2012 11:33 am
Yeah it's sorted. Was rear ball joints as suspected. I also had the tell tale clunk when pulling away from a stand still.
jaynana
Post by jaynana » Sat May 12, 2012 7:25 pm
[quote=""dirtymonkey29""]Yeah it's sorted. Was rear ball joints as suspected. I also had the tell tale clunk when pulling away from a stand still.[/quote]
Its workin again, I didn't do anything - on its own but sometimes I get a long beep from the rear, with nothing around. So it must be the rear.
I'll let sleeping dogs sleep for now..
dirtymonkey29
Post by dirtymonkey29 » Sat May 12, 2012 7:48 pm
Don't you have bmwscanner? That'll tell you which one is the dud.
Rears are really easy to change. I got my sensors off Partsgateway for £30ish used.
Just don't buy from raw spares! There terrible... Read there reviews on there.
jaynana
Post by jaynana » Sat May 12, 2012 8:34 pm
I have a scanner.
Thanks for the lead - partsgateway.
dirtymonkey29
Post by dirtymonkey29 » Sat May 12, 2012 8:44 pm
Thought so. You'll be able to find out which one you need then.
The two front inner sensors are the same as all the rears. Only the two front outers are different (L shape).
XV
Post by XV » Fri Feb 22, 2013 8:04 pm
[quote="macky"]
Apologies for the thread resurrection.  My wife's X5 has a squeak from the rear suspension - like so many it seems.
Can anyone tell me how to release the air from the air bags and, more importantly, now to recharge them again?
shadrack
Post by shadrack » Fri Feb 22, 2013 10:12 pm
[quote="XV"]
[quote="macky"]
to relaese the air i jacked up the rear, axle stand under each side, removed the fuse/s fo the air suspension (rear right hand side cubord in boot), then lift up the boot floor, on the right hand side there are two plastic pipes one red one blue with a straight connector with a nut on, undo the nut to release the pipe and letting all the air pressure out, to re in flate reverse the instructions
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
XV
Post by XV » Sat Feb 23, 2013 1:28 pm
[quote="shadrack"]to relaese the air i jacked up the rear, axle stand under each side, removed the fuse/s fo the air suspension (rear right hand side cubord in boot), then lift up the boot floor, on the right hand side there are two plastic pipes one red one blue with a straight connector with a nut on, undo the nut to release the pipe and letting all the air pressure out, to re in flate reverse the instructions
Many thanks. :thumbsup:
This worked perfectly - much easier than I expected too  :)
XV
Post by XV » Sat Feb 23, 2013 7:32 pm
GRRR!!!!!!!  Squeaking is just as bad as it was.
Discharged the air suspension and removed and copper greased all the bolts and also smeared the edges of the bushes.  I checked the bushes and saw no obvious signs of wear.  Before I recharged the suspension a was able to jack the assembly up and down repeatedly without any noise at all.
It only seems to happen under load - it's starting to drive me nuts.
Any ideas welcomed.
Post by X5Sport » Sat Feb 23, 2013 9:57 pm
Could be a failing bush in one of the arms perhaps?  What's the play like on those?
XV
Post by XV » Sun Feb 24, 2013 11:27 am
Revisited this earlier this morning.
No play in the arms but the lower balljoint (the one between the hub carrier and the bottom wishbone) is hosed - how did I miss that  :-[
Raj
Post by Raj » Mon Feb 25, 2013 7:52 am
[quote="XV"]
Squeaking is usually the ball joint. Can be done yourself if you have the tool. I've replaced both mine. To look at they look fine until you get them out and they just fall apart. I have the tool if you do wish to hire it.
XV
Post by XV » Mon Feb 25, 2013 7:40 pm
[quote="Raj"]
Many thanks for the kind offer but it's going to a local garage on Wednesday - I just don't have the time to self mechanic any more.
