[quote=""shadrack""]disagree again, i had budgets on my m3 and it is worse than driving a scooby!![/quote]
Well as I said and will say it again, if your happy then fine.
But when all said and done, there is no way budgets tyres can be as good as premium tyres.
http://www.youtube.com/watch?v=e2c9Ry0J ... ata_player
So you might think there good, but when safety and my kids life's can be at risk, no thanks.
I fail to find any information as where budgets are better, or Evan close to premium tyres in wet weather grip.
Maybe you can link use to some hard evidence, so we all can save on buying premium tyres. As said the last time I used erm was around 7 yrs ago, and times change. So I'm happy to be proven wrong, but read the copy and paste below.
Budget tyres are controversial topic. UK is known to Europe as the "dumping ground" for cheap tyres, and we have a higher percentage of budget tyres fitted to our cars than anywhere else on the Continent.
A tyres a tyre...
Most people who fit budget tyres do so based on price, why spend £300 on a set of 4 premium tyres when you can spend £150 on a set of budget tyres? To anyone outside the tyre industry, a tyre can be just a black, round thing that holds your car of the road, but with premium brand manufacturers spending hundreds of millions of pounds each year on tyre research and development, budget and premium tyres have vastly different properties.
What does it mean in the real world?
To highlight the issue, Continental recently invited us to MIRA to drive two identical Ford Focus vehicles wearing the same size tyres, with the same tread depth and the same tyre pressures. The only difference? One vehicle was fitted with the multiple award winning Continental Premium Contact 2, and the other a budget tyre called "Triangle CNNT GLS".
The wet handling area comprised of a windy track section which demonstrated how the tyres react to high speed direction change, emergency braking and how well balanced the vehicle is. A second test, driven around a constant radius circle designed to simulate a large British roundabout in typical British weather (rain!) allowed us to measure corning speeds and how the car reacted to steering inputs at the limit of grip.
The first test comprised of the Continental Premium Contact 2 on the handling circuit. As you would expect from a wet surface, the traction wasn't as high as it is in the dry, but the car felt like it had plenty of grip, reacting well to our steering and throttle inputs. During the emergence braking the car peaked at 0.82g, and peaked at a similar 0.77G laterally in the corners.
Next up, the constant radius circle, with the Contis providing an average "on the limit grip" speed of 35mph, but offering plenty of feedback as the limit was reached, and subsequently passed. Once passed the limit of grip, the tyres let you know with plenty of feedback and understeer, and while understeer is a dull handling quality, it is is also a very safe quality. Average G on the low grip circle, 0.32g. "Immediately the difference was obvious. The car had much less grip, extremely vague steering and you had very little feedback as to whether the tyre was gripping or sliding."
The Budget Tyre
Next up was the turn of the budget Triangle on the wet handling circuit. Immediately the difference was obvious. The car had much less grip, extremely vague steering and you had very little feedback as to whether the tyre was gripping or sliding. Power understeer, something barely noticed with the premium tyre was much more of an issue, with the grip disappearing quickly and taking a long time to regain control once the tyre started sliding. The constantly circle proved even more worrying, with the car seemingly switching between understeer and oversteer with very little steering feel or input. Peak Gs? A meer 0.61G under braking and just 0.55G laterally, some 30% less than the premium tyre.
We get a lot of questions asking whether budget tyres are worth the saving, and we can now say with certianty they are not. Its not just the lack of raw grip, it's how the car reacts at the limit, and how much control you have once past the limit. A well developed premium tyre has been tested in all situations, where a budget tyre is an unknown quantity.
Sent from the Iphone via talktapa
Budget Tyres
Budget Tyres
The tyre brand in that review is 'Triangle' which I mentioned earlier I tried myself and didn't particularly get on with. They are a serious budget tyre! i.e £45 for an 18" tyre! The quality was terrible.
Im not saying that budgets are the same as premium or anything, I'm just saying I'm not planning any trips to the Nurburgring any time soon and generally drive the X5 pretty sensibly so I doubt i'd even notice the difference spending £350 on a tyre or the £110 that I just spent.
I take the Internet reviews with a pinch of salt to a certain degree, you can search the Internet and find a load or reviews of people who's iPhone have caught on fire or the dangers or choking on a cabbage leaf, but at the end of the day, I have repeatedly run budgets on my own car with me at the wheel for over ten years. I've used them in Sun Rain and Snow and in that time as you can imagine I've had to do my share of emergency stops for whatever reason and never had an issue.
I generally avoid any 'absolute dirt cheap' budgets that I've never heard of like 'sunny' who do a 20" tyre for £50 that seems to be made out of plastic more than rubber! I made that mistake with the 'triangles' as mentioned above.
As mentioned in the 2nd post on the thread, the 'big players' generally back a number of the budget companies anyway!
Anyway, each to their own
2004 Silver 3.0D Sport Auto - 20" Le Mans Rims, Gen 4 Hualingan DVD/BT/iPod/SD/Nav Headunit, E70 Rear Wiper Conversion, Front Bosch Aero Flatblades
Re: Budget Tyres
A quick google delivered the following family tree:
http://www.rubbernews.com/subscriber/ra ... om2007.pdf
~S.
~S.
Budget Tyres
Bumping so I can find later
Budget Tyres
The link doesn't show much about who owns who in the Budget world though.
