Tyre pressure sensors
Post by sapphireblack » Tue Apr 10, 2012 9:56 am
I'm sure there was a thread, with a link to the makers of the earlier system sensors???? but accepting my search skill are poor i can't find any reference to this.
Anyone know who the actual makers are to by-pass increasing BMW profits?
TIA :)
I should add, i recall it is (was) Beru but they seem to have sold that side of their business? They're over £100 a pop on eBay :o
Last edited by sapphireblack on Tue Apr 10, 2012 10:27 am, edited 1 time in total.
2009 35d, Space Grey with Chateau leather, just crept over 40k miles.
JonW
Post by JonW » Tue Apr 10, 2012 10:17 am
Hi,
I was looking at these last week and found 3 listed onrealoem.com for around £30 + vat each. In the end up I decided just to switch the system off and save the expense.
I think this may have been the link for the aftermarket ones
http://www.alloywheelsdirect.net/option/tpm_sensors
JonW
Current ~ X5 4.6is, Z4 3.0se, Mini Cooper D, Astra Estate1.6lpg.
weirdfish
Re: Tyre pressure sensors
Post by weirdfish » Tue Apr 10, 2012 10:34 am
Correct me if I'm wrong, but in order to switch the system off don't you have to re-progg. the software, so as it's not looking for any pressure difference, and don't forget, there is a sensor in the spare wheel as well.
Post by sapphireblack » Tue Apr 10, 2012 10:39 am
Thanks for the link which does look familiar :)
Surprisingly their pricing is more than my dealers quote but with both hovering around £300 for four sensors, plus the hassle and further expense of the swap over it's prohibitive.
On the early systems such as on my car, i'm assured it can't be switched off hence the endless message/s and gong/s become an irritant :(
JonW
Post by JonW » Tue Apr 10, 2012 11:22 am
Hi,
You can switch off the check control message so you don't get any dash warnings. I've done it with one of the scanners from eBay that allows you to choose what warnings are shown on the dash. Technically the system is still on but you don't get any information from it so no warning lights or gongs.
JonW
JonW
Post by JonW » Tue Apr 10, 2012 11:28 am
Here's the eBay item number for the scanner 260724901876. I don't know if it will work for yor car but mines a 2003.
JonW
Post by sapphireblack » Tue Apr 10, 2012 11:52 am
Thank for your input. I don't actually own laptop but ahve frends who do so anything is acheivable in theory.
Do you (or anyone else) know for sure just the warning part of the TPMS can be disabled? I don't want to switch off all the warnings just this PITA one ;)
JonW
Post by JonW » Tue Apr 10, 2012 12:11 pm
I bought my car with 1 sensor missing and the warning light on ( previous owner told me it had been removed) so like yourself I priced up the parts looking at the worst case of all 4 sensors being needed and found it to expensive.
The scanner gives you an option page for check control messages that lists the full set of warnings that can be displayed. All you need to do is untick the box for tyre pressures to disable the tyre warning light.
This does not affect any of your other warnings however you can choose to activate or disable any check control message you wish.
My car is running with only 3 sensors and no tyre warning lights or gongs whatsoever but every other warning light is working perfectly. This morning I drove off with the boot not closed properly and the warning for boot flashed up immediately.
Raj
Post by Raj » Tue Apr 10, 2012 1:45 pm
My Alpina Dynamics actually have three of the metal sensor valves attached (for the pressure sensors) as the rims were originally bought 9 odd years ago from a dealer in Kings Lynn. Whether the sensors are still attached to the back is anyones guess. Too much hassle/cost to have the tyres removed and refitted just to check. But would prefer to have standard valves fitted as my E53 uses the updated system.
Post by sapphireblack » Tue Apr 10, 2012 2:25 pm
[quote=""JonW""]I bought my car with 1 sensor missing and the warning light on ( previous owner told me it had been removed) so like yourself I priced up the parts looking at the worst case of all 4 sensors being needed and found it to expensive.
My car is running with only 3 sensors and no tyre warning lights or gongs whatsoever but every other warning light is working perfectly. This morning I drove off with the boot not closed properly and the warning for boot flashed up immediately.[/quote]
Thanks for this, i will procure a scanner and lean on a buddy with a lap-top :)
EDIT
The seller of this item says it wont do what i'd like done?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123
bonerp
Post by bonerp » Tue Apr 10, 2012 5:34 pm
check the laptop runs nothing higher than xp. I dont believe you can use the scanners on win7 64 bit home version. Might be able to run the laptop in xp mode if they have premium...
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
JonW
Post by JonW » Tue Apr 10, 2012 6:33 pm
Post by sapphireblack » Tue Apr 10, 2012 8:17 pm
[quote=""JonW""]This is the one I have.
http://www.ebay.co.uk/itm/260724901876? ... 2723wt_745[/quote]
Hmm, that looks to be just the same as the one i linked too! Maybe the seller doesn't know enough about what he is selling? Tedious :roll:
