Cracked Alloys
squeaky2
Cracked Alloys
Had the rear tyres changed today and have discovered a small crack in one of the alloys.
Before i put the summer wheels back on i cleaned up the alloys and am sure the crack wasnt there.
I know BMW have had problems with this in the past but do you think there is any chance BMW will replace the wheel under AUC warranty?
graemeX5
Re: Cracked Alloys
Would probably depend how old the car / alloys are and what you warranty says as to a defect in wheel or is it considered to be your fault and how ameniable your dealer is, but def Worth asking. Although from experience with vauxhalls dont hold your breath
Re: Cracked Alloys
If the rim is undamaged I can't see how they could wriggle out of it - though they'll probably try. Read your warranty docs to see what's excluded.
Never anthropomorphise computers. They hate that.- shadrack
Re: Cracked Alloys
they may blame it on pot holes in the road and who could blame them, uk roads are a joke!!
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
- stevox5
Re: Cracked Alloys
The usual process involves the dealer removing the tyre and measuring runout of the wheel rim with a DTI guage to asess if the crack is due to impact dammage . Once this is assesed the dealer can submit a queery to BMW uk for assesment of the findings and to see if BMW will contribute or relpace the wheel.X5 wheels are not the usual wheel design that is refered to as the BMW wheel with issues this is a 19 inch rim fitted to the three series .
If you have a good relationship with your dealer I would explain the problem and invite them to see what they can do for you.
Hope you get a result.
X5 3.0i Topaz Blue , Paddle shift steering wheel , Pioneer double din sat nav,Alpine speaker upgrade, Remap, HID's,20inch lemans alloys,lemans arch kit,Depo light kit,carbon fiber interior wrap.
squeaky2
Re: Cracked Alloys
Hrmmm.....it doesnt sound like i should hold out much hope.
The tyre guys put some chemical metal stuff on it as i need the car for the weekend. They also have someone who can weld it as the crack is only about 1cm long.
I will give BMW a call in the morning and see where it might lead.
Back to the downside of not having a spare either i suppose
Re: Cracked Alloys
We had an 18" M-Sport rim on the E46 badly damaged by a pothole. Local guy who does work for Aston Martin fixed if for £70.
I have to admit it is the one thing I really don't like about not having a spare or emergency wheel!!
Raj
Re: Cracked Alloys
This is the problem with RFT's too as they don't have any give in them so all the shock when hitting a pothole, etc is transferred to the alloy.
I'd definitely talk to BMW about I though as you should be able to a decent case forward for a good will gesture if it isn't covered under your warranty.
squeaky2
Re: Cracked Alloys
Been into BMW today and they were saying i need to get the wheel into them and for them to check the runout (i think) Something about if its less than 2mm then they can put in for a case of goodwill replacment.
The tyre guys i deal with say they know someone who can do a very good repair on it.
Im now not sure which way to go on all this.
Re: Cracked Alloys
Use BMW as your first option - unless you know someone with a dial gauge? What they do is to put the wheel on a jig and rotate it to see if the rim goes in or out by more than 2mm total from the reference point they choose (a bit that is even when they put the gauge up to it). Then repeat the process on the other rim. Add or subtract the maximum variance from the reference to give you the total runout. You can do it on the car if you know someone (albeit, that's a bit more fiddly). Only takes 15 mins to do.
If BMW then won't play because of excess runout - which will most likely be pothole damage - then go to your contacts. You may even find BMW can fix it. My dealer offers that repair service for alloys. Can't remember how much though. A new wheel would always be my preference unless the guys doing the welding know what they're about, in which case no problem.
squeaky2
Re: Cracked Alloys
[quote=""X5Sport""] My dealer offers that repair service for alloys. Can't remember how much though. [/quote]
Not a surprise the dealers offer a repair service......they are probably experts by now.
The service guy i spoke too basically said that its the problem having an elastic band with a rock sidewall and a soft alloy
graemeX5
Re: Cracked Alloys
That certainly sounds more promising and as X5Sport said use BMW dealer as first option.
If they can assess it there and then thats good. But if they have to keep the wheel they may even be able to supply a temporary one worth asking.
Re: Cracked Alloys
[quote=""squeaky2""]The service guy i spoke too basically said that its the problem having an elastic band with a rock sidewall and a soft alloy
He's got a point, and more so on the more delicate designs. There are a few I've seen on the interwebs which defo made me wonder how long they would last on our roads and with RFTs fitted!
A number of discussion forums have suggested it is a very good reason to never buy 'copy' or 'look alike' wheels over OEM as the quality controls may not be good and the alloys softer.
Hopefully this will be a straight swap......
