scanner 1.4 broke my clock
gadgetJunky72
Post by gadgetJunky72 » Fri Mar 30, 2012 12:13 pm
Hi folks,
well ok. it didn't break it i did.
i thought i'd try the GPS / RDS sync options on the IKE module. Things were working fine until the clocks went forward an hour and they didn't in the X5. Every time i manually move the hour forward it re-syncs and is an hour behind again.
I've tried unchecking the options using the scanner tool but it still keeps on syncing to something.
anyone had this before or know of a way to reset changes made using the scanner tool?
Pav
amacman
Re: scanner 1.4 broke my clock
Post by amacman » Fri Mar 30, 2012 6:24 pm
I would just like to say :rtfm:
Did you press set then adjust time then press set again to confirm adjustment .
No scanner or tools required to do this , only a normal function of the car clock .
gadgetJunky72
Post by gadgetJunky72 » Fri Mar 30, 2012 6:35 pm
[quote=""amacman""]I would just like to say :rtfm:
No scanner or tools required to do this , only a normal function of the car clock .[/quote]
yep. the time does get set for a while, but then re-syncs somehow and returns to 1 hour before.
Post by X5Sport » Fri Mar 30, 2012 6:58 pm
How long is 'a while'?
New one on me too. I didn't think the clock synced with anything, or is even connected to any other car function. As the man says, it's just a clock :scratchhead:
Even the latest models with all their toys and DAB radios etc still don't sync automatically.
pvr
Post by pvr » Fri Mar 30, 2012 7:01 pm
Do you have an Intravee? That is the only unit I know that controls the clock via GPS.
911 50th anniversary -
gadgetJunky72
Post by gadgetJunky72 » Fri Mar 30, 2012 7:21 pm
yep. i've got an Intravee with the extras.
I think it's happened because i ticked a checkbox on the IKE module called GPS-clock and unchecking hasn't undone this change.
i've got the Intravee user guide so i'll have a look if that might be the reason why.
X5Driver
Post by X5Driver » Fri Mar 30, 2012 7:38 pm
Odd as since I scanned my car my iPhone name has changed on bluetooth only showing the first 3 letters and everytime i scan it turns on aux ventilation and sets the time to something non exist and like 33.76 hours
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Post by X5Sport » Fri Mar 30, 2012 8:13 pm
[quote=""gadgetJunky72""]yep. i've got an Intravee with the extras.
I think it's happened because i ticked a checkbox on the IKE module called GPS-clock and unchecking hasn't undone this change.[/quote]
Got to be worth a punt. GPS clocks run in UTC which makes sense given the hour shift you keep seeing.
gadgetJunky72
Post by gadgetJunky72 » Fri Mar 30, 2012 8:15 pm
[quote=""pvr""]Do you have an Intravee? That is the only unit I know that controls the clock via GPS.[/quote]
thanks pvr i think that fixed it.
amacman
Post by amacman » Fri Mar 30, 2012 10:22 pm
:scratchhead: :idunno: :voodoo: .
shadrack
Post by shadrack » Mon Apr 16, 2012 7:04 am
[quote=""pgveeec""]scanner broke your clock?
i bought Newest S620 with my car in chinasinoy.com.
i felt this tool is great.[/quote]
I feel your a tool :fuelfire:
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
