E70 Hidden Menus
How-To articles go here.
Black X5
E70 Hidden Menus
Post by Black X5 » Fri Mar 23, 2012 5:44 pm
Hidden menus - work on most BMWs from 06 -> here
Good one to keep an eye on is Menu 7.00 (Engine coolant temperature). Should normally run around 92C (in stationary traffic, or crusing on the motorway).
If it is less than 90C, chances are it WILL be affecting your fuel economy.
Whats causing it? Themostats - both of them. E70 diesels have 2 thermostats, one for the EGR and one for the main engine coolant.
If either of these is even slightly stuck open, the engine never reaches its full working temperature. Results in:
ECU thinks engine is cool, and keeps injecting more fuel than needed,
AND
Combustion isn't as efficient as it could be (well not more than 40 odd percent anyway! :cry: )
Plenty of info on the net on how to change them here:
Main thermostat replacement text
EGR thermostat replacement Video
E70 3.0D SE, Black with Black - Gone but not forgotten!  >:D
i_dinler
Re: E70 Hidden Menus
Post by i_dinler » Thu Mar 29, 2012 8:05 am
Good info! We all like looking at places we shouldn't be looking at! :P
After looking at that article, I would probably stay away, all that code numbers got me dizzy :?
acideraser
Post by acideraser » Thu Mar 29, 2012 5:28 pm
thanks Black X5, this is very interesting.
Will give it a try
2011 X5 xDrive30d SE Platinum Grey 20" 336 alloys
Garthoffradley
Post by Garthoffradley » Thu Jul 04, 2013 5:47 pm
Hi,I've just checked this (Thanks!) and it comes out at 85 degrees .I've only recently just bought it and its got 12 months warranty but would they change it under warranty or would it be not classed as a fault?
