Sunroof question
dirtymonkey29
Sunroof question
Post by dirtymonkey29 » Mon Mar 26, 2012 3:36 pm
Is the rear portion of the sunroof meant to slide back when you open the sunroof fully? If I open it to tilt position then front and rear glass tilts so I think I have a fully working sunroof at the moment.
X5Driver
Re: Sunroof question
Post by X5Driver » Mon Mar 26, 2012 5:49 pm
Pretty sure it does no sliding, the front tucks under the rear. They both tilt also with the sunblind across when you tilt it should part in the middle with a mesh strip
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
dirtymonkey29
Sunroof question
Post by dirtymonkey29 » Mon Mar 26, 2012 6:14 pm
That's right. One push upwards tilts both glass bits and the cover splits open with the mesh in the middle
Post by X5Sport » Mon Mar 26, 2012 7:10 pm
Sounds normal, or at least exactly what mine used to do. One push to the rear moved the roof back to its first stop, two pushes all the way back. I can't remember what the rear section did in that case though.
When the front panel slides back you also get an anti-draft device popping up too. If you ever get onto a test track you will find the anti-draft device auto lowers at speeds in excess of 110mph.
Being a Fleet Manager in my previous job gave me access to Millbrook once a year. I did take an X5 around the oval a few times, and at speeds around 110mph and noted the device retracting. I miss that track access, although I do still get invites every year in June. All sorts of manufacturers were there and all the tracks except the 'Mile' were open - it was the Car Park. You do have to be a Business Fleet Manager to attend though, and I don't know if BMW attend anymore.
I do remember being aboard a Police marked up Skoda Octavia vRS and being driven by a test driver when he flashed an Astra Turbo VRX 'out of the way' at more than 155mph in Lane 5 whilst 4-up though..... :D . We passed it with ease, and the faces of the passengers were a picture, as if they were all saying "but that's a Skoda and it left us for dust!" We were only allowed to use Lane 5 if accompanied by a qualified test driver. Mere mortals could use up to Lane 4 as long as we didn't exceed 110mph....ish... :oops:
