Toys in your car cable
- wilkoturbo
Hi all bought the cable fitted in reverse cam and rear screens all done but I've bought an iPhone av cable if I plug it into the av in on that cable how will I get the sound out the nav ??
bmw x5 le mans blue
- wilkoturbo
Re: Toys in your car cable
Pass. I had the official 3.5mm adapter system in the glovebox. That worked via Aux. No control of the idevice possible though.
Never anthropomorphise computers. They hate that.- wilkoturbo
- Sanj
Select Television and AUX is the last channel.
Let us know if it works. Usually the Apple products are too low a signal to work.
- wilkoturbo
- Sanj
Unless the video from the iPhone will work... if you play videos. Otherwise audio will just be that, a blank screen.
Get an Intravee and be done with it!
- wilkoturbo
If you want full control of the idevice then as Sanj says you will need an external solution. The only limited support BMW provided when I bought mine was a cable that plugged into the Aux port on the back of the Nav head and allowed connection via the iPod headphone socket into a 3.5mm stereo jack socket in the glovebox. I think that cable is still available. I have a copy of the BMW fitting instructions in PDF format but will need an email address to send them to you as we can't attach said documents (Mods - that's a hint
BMW did not provide an integrated OEM solution until much later models appeared and the right options were in the car. I had an Ice>Link plus in my E53 which when it worked was great, but it meant I lost use of the CD multichanger. When it wasn't working nicely then it was a mare to get it working nicely again and product support was awful being based in Eastern Europe.
There is a US based DICE option but I have no experience of their products with the E53. Support is however supposed to be much better.
Never anthropomorphise computers. They hate that.- Sanj
Support of the Intravee is exemplary - it's British!
And then you get all the extras too. No messing, it does everything you expect (all on the screen and through the steering wheel controls too).
You should know better than to ask what you need btw! You've been on this forum long enough! Search button you tart!
An Intravee and the Apline KCA-420i (with both cables) is all you need. From new they will NOT have the Extras firmware, you'll need a friendly forum member...
And I bet Sanj can do some negotiating for you too......
Never anthropomorphise computers. They hate that.- X5Driver
Sanj what is the alpine kca420i bit for exactly does everyone need this.
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Never anthropomorphise computers. They hate that.- CondorX5
I have a spare KCA420i........
X5 2005 Le Mans Blue 4.8is
- wilkoturbo
