Rear suspension [squeak]
Help.... a loud squeaking coming from the drivers /side rear, while driving and if I rock it while its parked. Its still under warranty but just want an idea what it might be before we take it back.E53 55reg 3.0d le mans. Cheers Ali..
Rear ball joint is most likely
Re: Rear suspension [squeak]
I had that. Squeaks particularly over speed humps and the like. Sounded like a old cart.Turned out to be ball joints rather than bushes (the other potential culprit). Good news in that it is a reasonably cheap repair.
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
Z1 1989 Top Red
It will be even cheaper if it's the rear anti roll bar bushes like mine was I would look at them first.
[quote=""Bandit""]Help.... a loud squeaking coming from the drivers /side rear, while driving and if I rock it while its parked. Its still under warranty but just want an idea what it might be before we take it back.E53 55reg 3.0d le mans. Cheers Ali..[/quote]
mine did that....it sound like one of those old squeeky pram springs of old...noticebale ay slow speeds over speed bumps and body articulation
it was a rear arm that had a ball joint on it at one end and a bush at the other end.
I think it was part 11 here
http://www.realoem.com/bmw/showparts.do ... g=33&fg=30
I'd go with rear ball joint but you need to get someone to rock it while you get under and have a look.
Thanks for the advice guys , its in the garage to day, they said it was the bushes so I ll wait and see what they ve done when I collect it. Thanks again.
What was the outcome of this....mines just started doing this, not yet worked out what it is though as its dark and cant see anything. Seems to be coming from the middle of the rear end though.
As you've probably seen dm mine turned out to be bushes one was cheap but the other was not sold separately so had to have a whole arm at the back
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
My guess is the rear wishbone ball joint but I need to get under it with a bar and someone to bounce in the back. Short on time at the moment so may have to pay to get it done
Not managed to locate the squeak yet, what's best way to test? On axel stands with the wheel off or just get under the back with a long screwdriver and have a poke around?
I'm having the same problem atm. I think I've narrowed it down to the airbag! Is there any way to lube/grease this to stop the noise.
Dirtymonkey, I jacked the car up and took wheel off, then put axle stand on disc/hub, this allowed me to work the jack up and down whilst working all the suspension components. Hope that helps.
05 3.0D Sport Black
It seemed to stop for a couple of days now it's back again, got to be a bush somewhere and my guess is still the ball joint on the wishbone. Booked in for Wednesday so will find out soon enough. Can't be bothered to check myself with the weather so nice this weekend.
I've been told that the bush being dry is squeaking and when you jack it up they find a greased spot and drag it around a bit which is why sometimes after jacking up they can go quiet but only for a while
Apparently a few people drill a small hole through the rubber towards the metal and use spray copper grease via a straw then a blob of mastic to stop any dirt going in there but I thought that was all a bit Heath robinson for an X5
Agree on the weather it's so damn nice makes everything seam rosy
Not even jacked it up. Let the garage deal with it lol
