Programming E70
pvr
Re: Programming E70
Post by pvr » Tue Mar 06, 2012 11:26 am
According to the Xoutpost thread, you can indeed. That is what I want to do as well.
911 50th anniversary -
acideraser
Re: Programming E70
Post by acideraser » Tue Mar 06, 2012 11:38 am
reading BMW coding website now but stil a bit worried about messing up with car electronics... it's not like changing smartphone firmware and jailbraking iphone ... it's like jailbraking £50k iphone :o :o :o
2011 X5 xDrive30d SE Platinum Grey 20" 336 alloys
petert
Re: Programming E70
Post by petert » Wed Mar 07, 2012 1:26 am
[quote=""X5Sport""]The HUD is a totally different dashboard upper panel and uses a special windscreen where the two glass sheets in laminated construction are at different angles (ie not in a parallel plane to each other - sometimes it helps to be a photographer) to avoid dual image reflection issues.
...the dashboard upper panel includes a projector unit that throws the image onto windscreen, so its definitely not just a progamming job.
Shame though eh?
Peter T
jbutterfill
Programming E70
Post by jbutterfill » Thu Apr 05, 2012 12:22 pm
I felt the same about coding my £50k car, two things helped me be less worried about it. Firstly there is a really good and detailed walkthrough guide, follow that to the T and you will be fine. Secondly, when you code you program Specific independent modules such as the kombi module ( speedo) or the ccc module ( Satnav) so you won't screw up the whole car.
