Thanks. Now - is it hard to route the cable up into centre console? Would love to use my iPhone instead of iPod.
M.[/quote]
This one is bit more tricky, all the wires you have are standard and should stretch:
1. Get the KCA to sit under the rear bench seat, there's a recess in the centre, should fit, mine did
2. The wires needs to be fed under the carpet to the centre console - take out the light in the rear footwell and get your hand in to bring the cable half way through
3. Each side of the console has side panels, these have the carpet on them you see, with a split in the middle. Front one has one screw in the front footwell either side, get that out and the panels then pop off
4. There is a screw either side of the base of the console right at the back, undo these and the console should be lose enough to push the rest of the wire through
5. Now take out the internal tray under the armrest, drill a hole big enough to feed the iPod connector cable through - now you have the iPod in the centre console.[/quote]
couldn't have put it better myself
