New Aux Heater under warranty
I was one of the many who's aux heater refused to work after being programmed, tried all sorts as per the many discussions on here but nothing..so car went for service this week asked to check it over and was identified as an internal failure of the unit so new one under warranty getting fitted next week...result, hopefully all will work well when done..
- wilkoturbo
- wilkoturbo
Did it work before reprogramming ? As mine does just not as a aux heater !
bmw x5 le mans blue
Re: New Aux Heater under warranty
Not entirely sure, the car is new to me and it was enabled more or less the same day I got it...?
- wilkoturbo
No was done with scanner..
- wilkoturbo
Did they ask any questions as I've booked mine in today I hope they just fix it as I just enabled it !!!;)
bmw x5 le mans blue
No questions at all, I mentioned nothing about the heater being enabled by scanner just that I was aware it was not operating as it should when the temperature was low coz there was no exhaust gases from it in minus 3 when it should have been firing up...
- wilkoturbo
Oh no think BMW have rumbled me they have just phoned and said not ever BMW was fitted with this option and they will check to see if mine had from new plus they asked for the remote I said previous owner must of lost it !!!!!
bmw x5 le mans blue
- wilkoturbo
does your webasto start when the engine starts in a cold morning say below 5c? to heat the interior before engine heating does the job?
if that doesn't happen you should tell them that - that's a standard feature of the car and warranty should cover it.
- wilkoturbo
Yeah it does work with the engine running just doesn't want to work via power pin one (
bmw x5 le mans blue
[quote=""wilkoturbo""]Yeah it does work with the engine running just doesn't want to work via power pin one ([/quote]
strange one that is...
then again, come to think of it..
is ur battery absolutely ok? i observed this once in my car before i replaced the battery.
i just managed to start it with power to pin one only once, never could start again. eventually i replaced the battery, and hurrah! webasto starts again on power to pin 1!
havin said that my webasto itself has a prob which i'm yet to fix..
- wilkoturbo
Well my battery is sh@t I could do with a new one I'll try this weekend many thanks
bmw x5 le mans blue
You could try connecting a battery charger to the car for a while and charge it just to make sure the battery is at over 12v, whilst still connected, try pin1 and see if the Webasto starts, battery charger amp meter if fitted would confirm if things are happening as current draw would increase.
Runabout - E92 3 Series Coupe
