foaming lance
Smeeagain
foaming lance
Post by Smeeagain » Tue Aug 31, 2010 6:08 pm
Hi - I am looking to get a snow foam lance for my pressure washer but they all seem to come with different style fittings - karcher etc - my pressure washer is great and dont want to replace it but it came from Wickes so dont know what style the fittings are - can anyoen help ?
pvr
Re: foaming lance
Post by pvr » Tue Aug 31, 2010 9:15 pm
Do you have a pic of the fixing? I have the lance but with karcher attachment.
911 50th anniversary -
Darnicmax
Re: foaming lance
Post by Darnicmax » Tue Aug 31, 2010 9:57 pm
I had the same issue....two power washers from the same company - each with different fiitings.
Problem was quickly and easily solved by sending photos of the connector on the lance to Autobrite (
http://shop.autobritedirect.co.uk/index.asp)
I dealt with a chap called Mark Moss via : sales@autobritedirect.co.uk
Next day I had two correctly supplied snow-foam attachments for my pressure washers. Perfect. :thumbsup:
Hope that helps
Darren
PS I am in no way affiliated with these guys...
Smeeagain
Re: foaming lance
Post by Smeeagain » Thu Sep 02, 2010 2:01 pm
ok, thanks to all - turns out with was a lavor fitting and fits perfectly. I got a litre of valet pro snow foam and the instructions say "dilute to suit foam system"! - wtf ? By that do they mean the plus/minus adjustment on it ? It also says 25ml to 50ml per car - so i put that amount in the bottle tht comes with the lance and presumably the water goes straight in from the input to the ket washer - or do i need to put liquid in the bottle too?
smee
pvr
Re: foaming lance
Post by pvr » Thu Sep 02, 2010 2:47 pm
I did a 1:5 mixture, so filled up the bottle with 20% concentrate, then added hot water to it to fill it up .
I use about a third of the bottle for each application, so all in all works out ok.
With that ratio, I get the following result:
pvr
Re: foaming lance
Post by pvr » Thu Sep 02, 2010 2:48 pm
This is the bottle:
x555
Re: foaming lance
Post by x555 » Thu Sep 02, 2010 3:07 pm
I usually put about an inch of snow foam in the bottle and fill up with warm water like pvr said.The plus and minus adjuster changes the spary of the foam ie thiner/thicker.The car should be fully covered in thick foam if it's done right.I then spray mine on with heated water aswell as i have a hot water presure washer :D
Smeeagain
Re: foaming lance
Post by Smeeagain » Thu Sep 02, 2010 3:22 pm
great - thanks - wish I could connect mine to hot water but cant - oh well
Pewters
Re: foaming lance
Post by Pewters » Thu Sep 02, 2010 4:34 pm
PVR i see you have the new foam lance.............how does it compare to the old one (assuming you had the old type) as my bottle has just broke.
pvr
Re: foaming lance
Post by pvr » Thu Sep 02, 2010 4:51 pm
Never had the old one, got the brass one straight away (I assume you are referring to the breaking issue? )
Pewters
Re: foaming lance
Post by Pewters » Thu Sep 02, 2010 5:33 pm
The pin on mine is loose and the neck of the bottle has cracked.........time for a new one me thinks
