Oil
- wilkoturbo
Oil
Hi all should the oil on my dip stick be all the way to the top , is this wrong or damaging the engine
Many thaks Paul
3.0d
Many thaks Paul
3.0d
bmw x5 le mans blue
Re: Oil
Oil, in any vehicle, should only be filled to the maximum mark indicated. Overfill is just as bad as underfill but in different ways but to put simply f it is above the maximum then it is not doing the engine/componentry any good. The maximum mark is there for a reason !
Re: Oil
As above, but also wait just a few mins (5 will do) for the (warmed) oil to drain back to the sump, and check it on level ground. Part of my drive is sloped slightly and makes a difference to the reading!
If it's still way over the mark, then you can get oil removers that go down the dipstick hole and you can then suck a bit out. Saves messing about under the car
Oil
[quote=""X5Sport""]
If it's still way over the mark, then you can get oil removers that go down the dipstick hole and you can then suck a bit out. Saves messing about under the car [/quote]
I have one of them (pella500) makes oil changes really easy
Re: Oil
[quote=""smeeagain""]Oil, in any vehicle, should only be filled to the maximum mark indicated. Overfill is just as bad as underfill but in different ways but to put simply f it is above the maximum then it is not doing the engine/componentry any good. The maximum mark is there for a reason ![/quote]
just typed the question into google.. and yahoo answered
http://answers.yahoo.com/question/index ... 218AADdI3x
- wilkoturbo
Re: Oil
Unless you were also seeing a lot of blue smoke I would think it's unlikely. But get any overfill out as soon as you can is definitely a course of action to take.
It's not unusual to see a little over the max mark, and usually with no ill effects at all.
See what it looks like when all is wiped off and settled and rechecked. You'll be fine
- wilkoturbo
Oil
[quote=""X5Sport""]That's normal for most diesel owners - if you're laying a smoke screen that's different unless your other name is 'Leadfoot'.. [/quote]
That'll be my name you are calling then, bloody great on the motorway at night, covert mode, ish
Runabout - E92 3 Series Coupe
- wilkoturbo
Oil
23 of jan oil light came on filled up now oil lights on again !!!!! There is a very very little damp spot underneath but NOT on the floor any ideas where it's going !!?
bmw x5 le mans blue
Re: Oil
How far have you driven since then? These engines do use oil. I think the BMW spec for the M57 diesel engine allows for about 0.5 litre/1,000 miles. Mine certainly used oil at that sort of rate when new but the rate slowed as the miles went on, but it always burned some oil between services. I expected that at some point the 'burn rate' would eventually climb again through normal wear.
The current N57S engine doesn't seem to use any at all so far.
- wilkoturbo
Oil
Not loads getting to work 120 nipping around town 30 maybe ? Just the lights on !
bmw x5 le mans blue
Re: Oil
What's the dipstick showing? I had a bad sensor replaced within 3 months of getting the car. The BMW Assistance Driver who came out said it was a 'known problem' with both the level and pressure sensors. Used to scare the cr@p out of me when the 'Stop! Low Oil Pressure!' warning came on.
I think the bottom to top mark is 1 litre so if you've only done 150 miles and lost that much oil and not laying a clear smoke trail then you have a leak - although your description of the vehicle and drive state belies that view.
