In the process of sorting a few bits on my newly acquired X5 and have now fixed the sat nav.
I understand this is a relatively common failure and some of the repair or replacement unit costs I found were pretty high.
It turns out the laser unit itself is often the problem. £50 on eBay secured a new one and a quick search of google turned up an outstanding guide complete with pictures.
It's a bit fiddly and requires a bit of soldering but with patience and attention it can be done inside an hour. Now works perfectly, albeit showing roads from 2004 (old disc).
I thoroughly recommend giving this a try if you've the same problem as I was expecting it to be a nightmare and it was actually ok.
	Sat nav repair
- pvw10
Re: Sat nav repair
Top ma n good to know
				Moh153
Re: Sat nav repair
what problems were you having mate with the sat nav unit??
and do you have a link for the laser please
thanks
thanks
