bluetooth issues
garioch
bluetooth issues
Post by garioch » Wed Dec 14, 2011 10:52 pm
Evening,
I'm having a bit (actually alot) of trouble trying to get my phone (iphone 4) to pair with the car. all i have on the screen is "activate phone", cant even get to the "bluetooth pairing" stage.
ive tried pushing the pair button for 3sec with ignition off, then holding for a further 3 with ignition in position 1. nothing happens.
after reading a few more threads on here i opened up centre armrest and found a few broken wires
no idea what they did but thought it was a good place to start.
after soldering the 3 wires back together i tried it but still no luck.
When i go into the bluetooth on my phone and search for devices it doesnt pick up anything... does this suggest that it is the BT module itself that is faultly?
Heres a pic of it and ariel to let you know which one ive got.
Any suggestions welcome.
cheers
05 3.0D Sport Black
EXPLORER
Re: bluetooth issues
Post by EXPLORER » Thu Dec 15, 2011 8:47 am
hi, just done my 3g i phone, on e53, when you press the butt, and key pos 1, do you have flashing leds like the e53, top right of screen, also do you get asked for pk code, pass key code, 4 numbers, supplied with your documents, mine did not work first time, couple of goes did it,
some do have probs with the 4 phone
regards
X5eireann
Post by X5eireann » Thu Dec 15, 2011 10:03 am
I've had issues with mine from day one!!! I might actually check the under the arm rest to see if there are any broken wires. When I was over at Sanj's - he tried to get it working and there was no joy. Its either a faulty Bluetooth Module, which is an expensive replacement (even secondhand they aren't cheap) and I think for the same money you could just purchase a Parrot, which will be much better than the OEM version.
It might possibly be the Bluetooth antenna which is usually mounted on the top of the rack (above the DVD). Let me know how you get on with this as I don't want to purchase a Bluetooth Module only to find that mine isn't faulty.
garioch
Post by garioch » Thu Dec 15, 2011 7:47 pm
i read somewhere that you can unplug the bt antenna which proves it faultly or not. i might try that. going to check wiring again first to double check everything is ok on that side of it. anyone know where you get a wring diagram so i can establish what wire does what and find out which ones were actually broken in the first place.
explorer, thats the stage im trying to get to but nothing happens when i press the pair button, everytime i try it im just hoping to see those lights flash lol.
05 3.0D Sport Black
Bargain Bucket
Post by Bargain Bucket » Thu Dec 15, 2011 7:52 pm
I couldn't get my bluetooth into pairing mode either. Eventually the following topic solved it for me.
viewtopic.php?f=8&t=988&p=10680&hilit=bluetooth+connector#p10680
BMW X5 3.0d M-Sport facelift (E53).
garioch
Post by garioch » Thu Dec 15, 2011 9:28 pm
could be onto something there Bargin Bucket! i was wondering how to get that part of armrest apart, will have a look at work tomorrow and report back.
thanks for the info mate.
05 3.0D Sport Black
Bargain Bucket
Post by Bargain Bucket » Thu Dec 15, 2011 9:47 pm
It's easy enough to get out but there are 4 very small torx head screws underneath which need to be undone to separate it into two halves. 2 screws at the front and 2 at the back. Took my a while to find the ones at the back.
garioch
Post by garioch » Thu Dec 22, 2011 9:46 pm
well, i had a look in the armrest and guess what i found!?...
so i connected it back together and put some tape to hold it in place, like so...
unfortunatly, it still not working and i'm running out of ideas fast!
think ive covered all the bases already, if anyone knows of anything else, even a long shot....
please let me know :)
05 3.0D Sport Black
ianmaney
bluetooth issues
Post by ianmaney » Fri Dec 23, 2011 6:27 am
I gave up with my BT from the start, had a Parrot fitted with the screen fitted snugly into the ashtray so it's invisible when the lids closed and a much better system
Current Cars:
X5 06 3.0d Sport (His)
1 Series 116 SE (Hers)
Current Bikes:
GSX-R1000k6 (His)
2010 Suzuki Gladius (Hers)
garioch
Post by garioch » Fri Dec 23, 2011 10:02 pm
that sounds like it could be the way forward! you got any pics?
05 3.0D Sport Black
ianmaney
bluetooth issues
Post by ianmaney » Sat Dec 24, 2011 7:30 am
I'll take a couple today and post them.
Current Cars:
Current Bikes:
GSX-R1000k6 (His)
ianmaney
bluetooth issues
Post by ianmaney » Sat Dec 24, 2011 1:05 pm
Here's the Parrot head unit in the ash tray, can't see it when the lids closed. Unfortunately I did crack the ash tray when it was fitted as it is quite a brittle plastic.
Current Cars:
Current Bikes:
GSX-R1000k6 (His)
Sanj
Post by Sanj » Sat Dec 24, 2011 6:18 pm
Ian, you know they make a replacement for the ashtray? I have one, it's rubberised finish on the inside. Can get you a part number off it if you want. Only £8-£10 as well!
ianmaney
bluetooth issues
Post by ianmaney » Sat Dec 24, 2011 7:00 pm
Sanj, your a star, can you get me the number please and I'll get one after Christmas
Current Cars:
Current Bikes:
GSX-R1000k6 (His)
Rusty
bluetooth issues
Post by Rusty » Sat Dec 24, 2011 9:43 pm
[quote=""ianmaney""]Sanj, your a star, can you get me the number please and I'll get one after Christmas[/quote]
The part number (courtesy of Sanj originally )
ashtray delete, part number:
51168402968
Hth
Runabout - E92 3 Series Coupe
