Glow Plugs
Smeeagain
Glow Plugs
I have a 2004 E53 X5 - 2 of the glow plugs are showing up as problematic on the scanner (starting is aloittle sluggish)
IS this an easy job for an amateur - I've done spark plugs before but never glow plugs
Only two are showing up on the sanner - how many are there and should they all be done - mileage is 115k and they've never been changed since I got the car at 72k
Thanks Smee
Thanks Smee
Re: Glow Plugs
3-litre diesel in which case it's a straight six engine with one plug per cylinder. Isn't it always the way! First signs of cold weather and out come all the gremlins to play - Glowplugs, door locks, batteries.......
Smeeagain
Re: Glow Plugs
easy to do ? Expensive ?
Re: Glow Plugs
Fiddly, and I think they're of the order of £50 a pop (i'm not 100% on that though, and that may be the OEM price). Never changed mine as I only got to 53k with the E53.
Have a look here: http://tis.spaghetticoder.org/s/view.pl?1/04/94/95
Never anthropomorphise computers. They hate that.- x555
Re: Glow Plugs
Did this a while back and the glow plugs were £18.59 each before vat and there are 6 as X5Sport said. Not the easiest of jobs this one as the inlet manifold has to come of iirc.
Dont think i did a how to on this but may have some pics to help amongst my threads.
- x555
Re: Glow Plugs
Here ya go
viewtopic.php?f=8&t=1106&hilit=+glow+plugs
BTW worth replacing them all as it's quite labour intensive to get them done
Smeeagain
Re: Glow Plugs
yes just worked out that it was worth having all done if inlet manifold has to come off !!
thanks
thanks
dirtymonkey29
Glow Plugs
Mine need doing too... Shopping list is getting longer
- Rusty
Glow Plugs
Jason's lot did mine, all six ( five were showing faulty via INPA ) when he did the injectors. It started fine before, but better after. Def worth doing.
You done yours yet Sanj?
Runabout - E92 3 Series Coupe
Mrgee
Re: Glow Plugs
Had the same only after a week of buying the car, a warning about injectors came up on the dash. Took it back obviously, but I didn't fell anything different in throttle response and starting the car once the warning light came up. Made me wonder that if it was out of warranty, would I have changed them?
Smeeagain
Re: Glow Plugs
Quote from trusted local (non bmw) garage
£64 plus for glowplugs.
Labour five hours - £187.50 plus vat
Basically £250 plus vat
Anything else I should get done at same time ?
dirtymonkey29
Glow Plugs
All mine except no 4 are showing on BMW scanner along with the glow plug control unit.... Bugger
Smeeagain
Re: Glow Plugs
I'd get them independently checked first. I've seen other posts here suggesting they needed replaced when they didn't. I'm no expert but if you have five out of six not working plus the control unit then you would struggle at the very least to start it if not impossible. Are you having problems starting ?
dirtymonkey29
Glow Plugs
Nope no problems at all but it hasn't really been that cold yet.
