Diesel will not start
Post by bluex5 » Sat Nov 19, 2011 11:17 am
Need help .
Latetly it's been taking a few attemps to start . Turning over a few times then starting . Same hot or cold .
Now this morning it will not start . It just turns over .
bluex5
bluex5
Re: Poor starting .
Post by 5wany » Sat Nov 19, 2011 3:37 pm
It is most likely the glow (heater) plugs, you may not need all 6, get them tested and replace.
I take it when it was running it was not lumpy so probablly not be fuel issue.
:music:
5wany
Post by Buster » Sat Nov 19, 2011 4:18 pm
Had a very similar issue with mine earlier this year, turned out to be the pre fuel pump relay behind the glove box. £10 for the relay and 10 mins to fit.
Buster
Re: Diesel will not start
Post by Turks » Sun Nov 20, 2011 2:43 am
Could be that or the fuel pump itself. I had the same symptoms and it turned out to be the High Pressure Fuel Pump. You should be able to hear a buzzing sound when you turn your key to position II, this is the Fuel Pump charging the fuel lines... mine was dead.
Hopefully it won't be too difficult to fix for you.
Turks.
Turks.
Present:
Past:
Past:
Turks
bluex5
X5eireann
Re: Poor starting .
Post by AW8 » Mon Nov 21, 2011 12:48 pm
Plugs or possibly control unit to same.
Could still be something else though.
You need to hook it up to a diagnostic reader IMO.
In abscence of being able to scan for codes your friend will have to test &/or replace various individual components in order to confirrm the fault/cause.
AW8
Re: Poor starting .
Post by bluex5 » Tue Nov 22, 2011 2:40 pm
Managed to start it by squirting easy start in the filter intake . But once turned off would'nt re-start . So should not be the relay tried a new pump today but still no luck ,
Any more ideas .
Any more ideas .
bluex5
bluex5
Post by AW8 » Tue Nov 22, 2011 5:25 pm
Topic merged with "Poor Starting" to avoid further duplicated content/replies.
AW8
Post by bluex5 » Wed Nov 23, 2011 4:24 pm
problem solved . It was a combunation of an injector not working properly and then causing the pump to work harder , then injector failing and pump failing . Not cheap but done and running like a dream .
Also did filter changes at the same time as it was in bits .
bluex5
Return to “Problems (E53 1st-gen, 2000-2006)”
Jump to
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
