does anyone know who makes the OEM upper wishbones?
- StewieG
55 E53 3.0d with Pano roof and full coms pack. Black with Black
dirtymonkey29
If I remember correctly I think it's lemforder
- StewieG
Re: does anyone know who makes the OEM upper wishbones?
is it?
BMW part for upper wishbone is around 120. ECP are doing it for 109. think i'll get it from ECP then.
dirtymonkey29
http://www.autohausaz.com/html/auto_parts_shopping.html
Half way down
any luck with your saggy bags?
Half way down
- StewieG
[quote=""dirtymonkey29""]http://www.autohausaz.com/html/auto_parts_shopping.html
Half way down
any luck with your saggy bags?[/quote]
DM you absolute legend. Im gonna sort my arms out first, then take care of the saggy sack....
Half way down
- kkodal78
what is the part #? i just purchased the whole front end parts to include control arms upper and lower (front and rear) ball joints,track control arms sway bar links for 190 quid. from US
dirtymonkey29
Good price if you've got oem parts, I won't touch parts that are not oem or made by oem manufacturer (same part without BMW logo) as if found out the hard way that pattern parts are usually slightly out on dimensions causing set up problems, usually weaker and bushes cheaper and last less than half the time.... I am a fussy f**ker though
- kkodal78
mines are made by a german company but not oem..made a huge difference on the ride though..
i don't blame you for watching out for yourself..oem is the best way to go but the prices on oem parts suck.
- kkodal78
http://www.hamburgtechnic.com/index.html
this is the company which made the parts i used
dirtymonkey29
As long as there same manufacturer with out BMW stamp I'm happy.... I think oem upper arms are around £180 from dealer but lemforder from eurocarparts around £80
- kkodal78
that's over %50 discount..that's not bad if you are getting oem quality
but one think i learned the hard way was if you change a part on one side the other parts will start going bad as the new part will make a change on how the parts assemble.
dirtymonkey29
Oh by the way stewie I have a tip for you. Before you jack car up, measure centre of the wheel to top of wheel arch and record that for later. Once youve changed the part but before you torque up to the right tension, get your jack under the hub and jack it up till centre of the hub and the wheel arch match up with your original measurement. If done this way they will be torqued up under load like there meant to be and the bushes will last a lot longer as they won't have the extra torsion you get when everything it tightened up when the cars on the ground
dirtymonkey29
[quote=""kkodal78""]that's over %50 discount..that's not bad if you are getting oem quality
but one think i learned the hard way was if you change a part on one side the other parts will start going bad as the new part will make a change on how the parts assemble.[/quote]
Spot on. When I did mine I did all the arms and drop links
- StewieG
[quote=""dirtymonkey29""]As long as there same manufacturer with out BMW stamp I'm happy.... I think oem upper arms are around £180 from dealer but lemforder from eurocarparts around £80[/quote]
DM,
Im looking at the upper arms on Euro vs the same part from BMW parts.
ON the ECP website, it states "Extra Information with hydro bearing and without joint (tension rod)"
Does BMW part come with joint(tension rod)
DM,
- StewieG
oem part number 31126769717
