Low on power
Pradaman
Low on power
Had my 55 plate x5 in for a service wife drove it back and said it felt low on power. took it round the block tonight and it feels very slow. It's a 3.0 d sport no lights are on any suggestions could there be a pipe off or something?
- wilkoturbo
Low on power
Have a look in the left hand side of the engine there is a black box with 2 tubes coming off it make sure they are on
bmw x5 le mans blue
EXPLORER
Re: Low on power
have they done engine breather/ seperator, check, they do it every third oil change
Re: Low on power
Sounds like a vacuum hose is off. Common issue after a service as those hoses can get knocked. As has been suggested, check all the small pipes and hoses on the LHS of the engine area.
Pradaman
Re: Low on power
Problem solved vacuum pipe off thanks very much for your advice guys. Bit peed off with the garage for putting it out like that!!? rant over!
jamesturner
Re: Low on power
I had same fault after having some work done on mine, A worrying time as I kept thinking about Turbo replacement. Glad you are sorted now and appreciated the help from this forum in rectifying the problem.
Regards Jt
Regards Jt
