I thought that some bushings would be suspect to failure as we have developed a 'wheel wobble' when braking down from higher speeds and also the rear clunk when pulling away, which i thought was the rear trailing arm bush....and still may be
Stuff i should have replaced earlier i suppose.... time, money and all that
Here's what the MOT flagged up...
This does seem spot on aswell as the fronts would create the 'wheel wobble' under braking and the rear one would explain the slightly more tyre wear to the rear O/S tyre that i noticed earlier tonight under inspection
My question to you guys/gals is have any of you used after market parts at cheaper cost...any recomendations and if so how have they been. I have used non oem parts before and been quite happy with the results of some but i am also aware of you generaly get what you have paid for
That and ive just checked with real oem and the original parts from bm are £192 each for the front wishbone/control arms
