Graeme.
Failed MOT
- gmc15
Failed MOT
My X5 has just failed it's MOT on worn ball joint on front nearside and worn ball joint on offside track rod end
Garage is going to give me a price to repair on Thursday and re-test. Suppose these cars are quite heavy on the suspension though. Good news was that everything else was OK
Graeme.
Graeme.
x6 M50d
Raj
Re: Failed MOT
Tbh, they are prone to fail unfortunately. But not a huge job and not bad that they were the only issue.
- Pewters
Failed MOT
Worth checking the cv boots to see how worn they are coz they are common to fail.
- Lee4.8is
Re: Failed MOT
[quote=""gmc15""]My X5 has just failed it's MOT on worn ball joint on front nearside and worn ball joint on offside track rod end
Graeme.[/quote]
Mine passed at the beginning of the month, but i had an advise on the front nearside ball joint aswell saying it was worn.
Glad everything else was ok,i always dread MOT time.
Graeme.[/quote]
Current...E90 330i M Spt Blue/Black 2006
640d M Spt Blue/White 2012
Previous...
Audi TTS Black 2012
E53 X5 4.8iS Blue 2004
E92 M3 White 2009
E85 Z4 MR 2006
E61 520d 2009
E90 330d 2006
TVR Cerbera 4.5 1998
Previous...
Audi TTS Black 2012
E92 M3 White 2009
E85 Z4 MR 2006
E61 520d 2009
E90 330d 2006
- gmc15
Re: Failed MOT
The car was raised on a ramp with the front wheels on a flat pad. The guy used a remote control to move the pad slightly from side to side so, from underneath the car you could see the stress on each of the suspension components. It was quite obvious that there was movement in the two ball joints, which I probably could not have found before the MOT.
x6 M50d
- Lee4.8is
Re: Failed MOT
Must admit i was pleased it was flagged up,as you say it wouldnt always be something you would notice.
The advise on mine says slight play in nearside ball joint.
Hope it all gets sorted for you,when it goes in, at not too much cost.
Previous...
Audi TTS Black 2012
E92 M3 White 2009
E85 Z4 MR 2006
E61 520d 2009
E90 330d 2006
Previous...
Audi TTS Black 2012
E92 M3 White 2009
E85 Z4 MR 2006
E61 520d 2009
E90 330d 2006
- Waka
Re: Failed MOT
Mine failed today on both CV gaitors and both (?) hand brake disks
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
- Pewters
Failed MOT
[quote=""Waka""]Mine failed today on both CV gaitors and both (?) hand brake disks
If your going to do them yourself gimme a shout coz there is an easier way.
- Waka
Re: Failed MOT
Thanks Pewters, very generous but I've had the work done at my local indy.
He's very good, but my only question is that he showed TWO disks to my wife when she picked up the car.
I was surprised that...
1. the hand brake consisted of two disks and
2. that they would need replacing at all. the car has done 73k but I can't image they get much wear...my days of hand-brake turns are long gone!
- pvr
Re: Failed MOT
I never use my handbrake and had a "notice" on the last MOT on that as well. Not sure what actually wears though as they are not used at all.
911 50th anniversary -
AW8
Re: Failed MOT
Handbrake consists of shoes effectrvely inside a drum.........I suspect I am using the wrong terminology & very mindful the actual rear brakes are discs and not drums. If handbrake not used then muck &/or corrosion build up can cause issues if handbrake pulled to tight or used frequently the cables can stretch.
I have read various interpretation as to correct procedure for adjustment a quick search of internet & various forums will yield variations on the bestr method
......In an ideal world the adjustment can be performed by removing just one wheel nut though ideally a corresponding mark on each rear disc & corresponding caliper (or disc cover) would help ensure correct positioning for access to the adjuster.
I dont know if it's possible to buy a special adjustment tool for the knurled adjusters at the rear. Flat screwdrivers often used but mixed results depending on excact size of the scrwedriver and width of head issues which may compromise access & manouverability.
weirdfish
Re: Failed MOT
The biggest problem with most auto vehicles is that the handbrake doesn't get used all the time, and thus it becomes less than 100%, this normally shows up at mot time when they do the rolling road brake test, I try to get into the habbit of using the handbrake as well as "P" mode, just to keep things working.
AW8
Re: Failed MOT
Totally agree albeit have had issues with adjustment going out on the manual Z3 too.
Not my favourite design & adjustment probably best conducted inside a low light using a very bright led torch. Due to restrcited view some patience is required when illuminating inside the adjustment aperture.
I suspect most experienced at doing these adjustments do so more by feel than sight.
- pvr
Re: Failed MOT
It makes you wonder if the handbrake needs to be part of the MOT test for auto boxes ...
AW8
Re: Failed MOT
I would say not.............I may be wrong but I believe roll back can still occur on extreme hill starts can still occur if handbrake not used.
