I get intermittent issue with my satnav.
Some days i will get into the car and the tmc on the monitor is red, and if i go into the navigation option it says something about inserting the dvd.
Other times it works absolutley fine.
Anyone else have/had this problem?
Intermittent satnav issue
- Sanj
Re: Intermittent satnav issue
Is the disc OEM? Or a copy?
Cookieuk
Its one from eurosatnav
- pvr
Copies are known to cause issues. Try the oem for a bit.
911 50th anniversary -
Cookieuk
Cheers, I had a little search for the original DVD and cant find it anywhere!
I have had a look on fleabay but not sure which one to get. Any suggestions? 53 plate pre facelift.
I think you can only buy the OEM DVDs from a BMW Dealer. They're around the £175 to £200 mark.
Check whether there are any issues with Classic FM in your area as they carry the TMC data. No Classic FM means no TMC. I had issues a few years back when there was some engineering work underway and the local tranmitter was on low power. The car kept losing the signal and the TMC flag went red.
