bmw scanner v 1.4.0
Graham_The_Baker
Re: bmw scanner v 1.4.0
Post by Graham_The_Baker » Mon Feb 14, 2011 10:25 pm
[quote=""Waka""]Thanks Graham. I've been in that menu but was looking at the reprogramming button and not coding...or the other way around!
Now I've found it, it doesn't seem to have activated, maybe next time I start the car.
Sanj, the picture is of the menu I couldn't get into, I know what to do when I get there...thanks anyway :rofl: :)[/quote]
Yeh the car will need to sleep before it will take affect. 10 mins should do it :thumbsup:
Graham
ChewingBacca
Post by ChewingBacca » Tue Feb 15, 2011 12:04 am
As above. Lock the car and make a brew.
Sundayjumper
Post by Sundayjumper » Thu Feb 17, 2011 10:37 am
Just thought I'd add to this thead as I've just received my scanner too. Ordered Sunday, arrived yesterday, all the way from China for just over £50 all-in :D
Small tip, search the non-UK ebay sites too. The supplier I bought from had these listed on ebay UK for £29.99 + £19.99 postage but also for EUR 29.90 + 19.90 post. Euros are cheaper than pounds so by going for the EUR listing I was able to get airmail delivery for the same price as surface mail on the UK listing 8)
It took a bit of head-scratching to understand the instructions that were linked to a couple of pages back, but once I realised the required drivers were actually in the program folder and not the ones that it told you to download at the start, it all worked fine. Much more user friendly than INPA. I need to delve into it further though. I expect INPA still has some advantages.
Anyway, well worth the money IMO, everyone who works on their own car should have one.
lordviper
Post by lordviper » Sun Feb 20, 2011 9:55 pm
[quote=""Sundayjumper""]Just thought I'd add to this thead as I've just received my scanner too. Ordered Sunday, arrived yesterday, all the way from China for just over £50 all-in :D
Anyway, well worth the money IMO, everyone who works on their own car should have one.[/quote]
hi there which seller did you use?
lordviper
Post by lordviper » Sun Feb 20, 2011 9:56 pm
All i want a scanner for is to enable the following
-auto locking
-audible beep when locking/unlocking
-parking lights to turn on for 30secs or so when locking.
can anyone confirm the above is possible before i invest?
thanks!
ChewingBacca
Post by ChewingBacca » Sun Feb 20, 2011 10:19 pm
The first two, no problem, Not sure about the third.
Are you looking to illuminate the path on your way from the car?
If so it should already be active.
Key out, flash the high beam should keep pathway lighting on for 40 secs.
lordviper
Post by lordviper » Mon Feb 21, 2011 12:07 pm
thanks for the reply mate
well i have a HID kit in my x and to illumiate the drive its sometimes easy to forget to flick the high beam but more importantly my HID kit warns against continual cold starts.
my angel eyes are pretty bright and good enough to do the job, so i was hoping to be able to do it with them automagically.
Nessimmersion
Post by Nessimmersion » Fri Jun 03, 2011 10:13 pm
Does anyone know if this scanner can be used to reset the dash service lights.
I've tried all the solutions available on google, the dash comes up with all the menu options while going through the steps but when switched on again the service lights are on again.:headbang:
I was hoping the scanner would be able to reset these.
justin0
Post by justin0 » Fri Jun 03, 2011 10:58 pm
Hi there,
Sorry to hijack the thread, does the aucoustic alarm work on pre face lift E53?
I have working INPA & DIS/PROGMAN, it was a complete pain in the a@@e to set up, originally my W7 was 64bit, it would not work at all! Is this perhaps an issue with the PA Soft scanner too?
After a clean 32bit install all was well, just a thought.. :poke:
2003 X5 3.0d Sport, Silver, Black Leather, Nav, Intravee & Mirror & Lock Mods, TV, DTUK Chip, Remote Heating.
GSXR 1000 K2, 150 BHP @ R/Wheel, P/Commander, TRE, Arrow 60mm Carbon/Titanium Sys, Brembo, Talon, Galfer Brakes, Rear Sets.
Golf GT TDI
wilkoturbo
bmw scanner v 1.4.0
Post by wilkoturbo » Sat Jun 04, 2011 7:50 am
Has anyone got one of the scanners in my area and willing to turn a few things on in my car ???? Sheffield
Many thanks Paul
bmw x5 le mans blue
Steamyrotter
Post by Steamyrotter » Sat Jun 04, 2011 11:56 pm
[quote=""justin0""]Hi there,
After a clean 32bit install all was well, just a thought.. :poke:[/quote]
If you are referring to the arming of the car alarm giving an audible blip then technically NO.
This is an option for USA only and not (technically) legal for Europe models (from supply)
However i think you can reflash the EWS module with usa version but may lose some other functionality.
I managed to accidently get ine to blip when trying to code the thing through Carsoft but took all other options out.
Had to reset ZKE for it to allow other things to work.
If however you are talking about "key left in" audible nag at you until you finally crack and take the things out then yes.
PS
this makes interesting reading (and i do not condone its use, that is at your own risk...)
http://forums.bimmerforums.com/forum/fo ... .php?f=233
Please note...
dirtymonkey29
Post by dirtymonkey29 » Mon Jun 27, 2011 10:12 pm
[quote=""wilkoturbo""]Has anyone got one of the scanners in my area and willing to turn a few things on in my car ???? Sheffield
Many thanks Paul[/quote]
what needs turning on?
wilkoturbo
bmw scanner v 1.4.0
Post by wilkoturbo » Fri Jul 22, 2011 3:41 pm
Unlocking beep please ;)
bmw x5 le mans blue
