Hi,
Having just serviced my car for the 1st time does anybody have any info on the DIY service tool which can be bought online for around £15. Is it any good and if so how does it work. Appreciate any help and info.
Regards Jt
Resetting Service Lights 2005 3.0d
- wilkoturbo
Re: Resetting Service Lights 2005 3.0d
BMW X5 Engine Oil Service reset
Turn the ignition to "0"
Press and hold odometer button and turn the ignition to "1".
Hold odometer button pressed for approximately 5 seconds until the display shows: "Inspektion Re /
Release and press odometer button again until Reset flashes
Release and press odometer button shortly.
Release and press odometer button again.
The next oil service interval will be shown and will disappear.
Oil service lamp is now reset
Note: To abort the procedure at any time: turn the ignition to "0".
Hi,
Thanks for the info I shall try it this afternoon and let you all know the outcome.
Regards Jt
Regards Jt
Do you know if this procedure will work on my E46?
Sent from my mobile device using Tapatalk
Runabout - E92 3 Series Coupe
i believe its the same procedure.
Thanks for that, I will give it a go later/tomorrow and let you know if it works : thumbsup:
